carlangas Posted March 4, 2005 Share Posted March 4, 2005 Hi all, I really need help with this as the deadline for this is today and I can't figure this out by myself. (see pic) At first I thought the black squares apearing were probably the caused by the pond water plane. it was originaly created with splines in autocad, well I redrew the thing using a regular polyline reimported the pline into max 6, it still gives me those black squares when I render. I deleted the pond water plane and have messed with different raytraced materials and still those black squares appear. I am using light tracer, my glass is just a raytraced std mat. with no transparency, I started noticing yellow blotches after I created and tweeked the water material, which was a std. mat with a bump map and a reflect-refract in the reflect slot. I have spent hours trying to fix this. whats likely causing this problem and how do I correct it? can I do some sort of purge or something to clean up the file? thanks a lot, hope you experts can get me out of this mess Link to comment Share on other sites More sharing options...
Tomas Posted March 4, 2005 Share Posted March 4, 2005 Carlos, what materail or what object is on the right side of the deck. There are two noticably bigger black blotches. It looks to me that the rest is comming from it. If you have some really black difuse color (255,255,255), try something less extreme. Just a thoughts, Tomas. Link to comment Share on other sites More sharing options...
carlangas Posted March 4, 2005 Author Share Posted March 4, 2005 Hi Tomas, Im not using any diffuse color that dark... Link to comment Share on other sites More sharing options...
lambros Posted March 4, 2005 Share Posted March 4, 2005 Have you tried applying a new standard material and rendering again? You will have to isolate the cause. If it renders ok, then there is a problem with the raytrace material. I see that the black spots appearing are in the lower part of the image, where bounces take effect (I assume that you are using bounces with the lightracer). Could you please post your settings (lightracer and raytrace material)? That would help! Link to comment Share on other sites More sharing options...
animart Posted March 4, 2005 Share Posted March 4, 2005 hola carlos esta muy raro el error ya trataste de renderizar sin materiales para detectar que esta causando el problema? alguna vez me a pasado ese problema y fue por culpa de un rpc que tenia alguna especie de conflicto con el raytrace intenta renderizar solo los muros y ver si te genera el error si no le vas aumentando poco a poco los materiales y ambientacion hasta que sepas que esta causando el error Link to comment Share on other sites More sharing options...
carlangas Posted March 4, 2005 Author Share Posted March 4, 2005 Im using 2 bounces, rays at 200, for the raytrace, ive used several materials, from scratch, raytrace and standard. i cant post all the settings, you see im at work now and im doing this on the side so I do all of it at home. I only tried changing the water material since is started giving me problems afterward, but ill try isolating the glass as well, didnt know rpc´s could give you those kinds of problems as well. Link to comment Share on other sites More sharing options...
lambros Posted March 4, 2005 Share Posted March 4, 2005 rpcs can be a real pain using gi, but I haven't experienced any problems with lightracer. So I suspect that the problem is the raytrace thing. Sometimes there are problems with self illuminating materials, so check if you have any Link to comment Share on other sites More sharing options...
carlangas Posted March 4, 2005 Author Share Posted March 4, 2005 I do, my walls are self iluminating but i stared to have problems with it before I had the self illuminting walls Link to comment Share on other sites More sharing options...
carlangas Posted March 4, 2005 Author Share Posted March 4, 2005 hola Fernando, voy a ver si son los rpcs, cambiando el tema, yo estoy apenas empesando con esto,mas o menos cuanto cobrarias por un trabajo asi? me daria una mejor idea de cuanto cobrar,,,, mil gracias Link to comment Share on other sites More sharing options...
mtb0506 Posted March 4, 2005 Share Posted March 4, 2005 hey carlos, have you checked out your raytracer settings? they may be going over the max depth, and thus filtering the bounces to a black color. it can be found in the render scene dialogue under raytracer. Link to comment Share on other sites More sharing options...
carlangas Posted March 4, 2005 Author Share Posted March 4, 2005 I set it at 3, default 9, are we talking about the same setting? Link to comment Share on other sites More sharing options...
abicalho Posted March 4, 2005 Share Posted March 4, 2005 This problem usually happens when one object in the scene has incorrect UVs. Add a new UVW Modifier to the grass, the skydome, and see if that fixes the problem. To find which object causes it, hide a couple objects and render, until the black squares go away. Link to comment Share on other sites More sharing options...
carlangas Posted March 4, 2005 Author Share Posted March 4, 2005 I didnt know you could add uvs to the skydome, how do you do that? Link to comment Share on other sites More sharing options...
animart Posted March 4, 2005 Share Posted March 4, 2005 se refiere a si tuvieras un objeto como cielo, como un cilindro o una media esfera a esos objetos les aplicas el uvw map y el material de cielo que tengas Link to comment Share on other sites More sharing options...
carlangas Posted March 4, 2005 Author Share Posted March 4, 2005 oh, pense que estaba hablando del skylight... leiste mi mensaje? Link to comment Share on other sites More sharing options...
abicalho Posted March 4, 2005 Share Posted March 4, 2005 Yo no sé como tu hiciste tu cielo, si és un Background o una esfera con el mapa del cielo. Si fuera una esfera, ella puede tener UVs incorrectos, y causar el problema. Yo creo que el problema del UV viene de la grama - reaplique UV a ella y tente hacer el render novamente. Otro detalle, creo que és mejor hablarmos en inglés en el forum. Muchos no entienden español. Link to comment Share on other sites More sharing options...
Tim Nelson Posted March 4, 2005 Share Posted March 4, 2005 Otro detalle, creo que és mejor hablarmos en inglés en el forum. Muchos no entienden español. Si es verdad! Link to comment Share on other sites More sharing options...
carlangas Posted March 4, 2005 Author Share Posted March 4, 2005 I agree Link to comment Share on other sites More sharing options...
animart Posted March 4, 2005 Share Posted March 4, 2005 yes sorry about spanish no there is no message do you send to my email? Link to comment Share on other sites More sharing options...
