VincentVega Posted March 7, 2005 Share Posted March 7, 2005 Hi, I just started with VIZ2005, but I have problems with the settings. As you can see the attached screenshot my whole creation looks very strange. You can see partically the inside and outside and different primitives through eachother. How could I solve this, because the render looks good. Which settings I have to change to have the same view in my viewport? Thank you very much Link to comment Share on other sites More sharing options...
lambros Posted March 7, 2005 Share Posted March 7, 2005 that looks weird man... Link to comment Share on other sites More sharing options...
abicalho Posted March 7, 2005 Share Posted March 7, 2005 Select all your objects, group them and move the group to 0,0,0. That will probably solve it. Link to comment Share on other sites More sharing options...
VincentVega Posted March 9, 2005 Author Share Posted March 9, 2005 abicalho said: Select all your objects, group them and move the group to 0,0,0. That will probably solve it. Unfortunately, it doesn´t help. All the objects go to (0,0,0) which makes a complete chaos Link to comment Share on other sites More sharing options...
DelfoZ Posted March 9, 2005 Share Posted March 9, 2005 abicalho said: Select all your objects, group them and move the group to 0,0,0. That will probably solve it. = 1- select all 2- GROUP all using group tool 3- after that move it to 0,0,0 4- ungroup all Link to comment Share on other sites More sharing options...
VincentVega Posted March 12, 2005 Author Share Posted March 12, 2005 Nope, it doesn't seem to help even a little bit Link to comment Share on other sites More sharing options...
Bugga_Guy Posted March 12, 2005 Share Posted March 12, 2005 I dunno if it will work but give these a try: 1. group the entire model, then move to 0,0,0. then ungroup. 2.Goto viewport configuration and and click the "force 2 sided dialogbox" 3.activate viewport clipping and play with the 2 arrows on the side of your screen. move them back see if anything happens. 4. play with your feild of view (the eye icon bottom right corner) Link to comment Share on other sites More sharing options...
Iain Denby Posted March 13, 2005 Share Posted March 13, 2005 Try merging evrything into a new file. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted March 15, 2005 Share Posted March 15, 2005 You coluld also try changing the video card driver in viz Link to comment Share on other sites More sharing options...
