radiosity benchmark (viz4)
Guest adrian_dav
Guest adrian_dav
hi,
i'm interested to see what kind of hardware configuration is optimal for radiosity processing in viz4.
i created a simple scene. it is available here. could you download it, run the radiosity solution up to 96% and post the time it took as well as the specs of the hardware you used?
please read the time used for the solution from the statistics roll-out in the radiosity panel.
thanks!
my trusty old dual-pentium3-boxes came up with the following results.
computer A:
CPU: 1000MHz Pentium III
number of CPUs: 2
RAM: 1024MB
motherboard: MSI 694D
time: 13minutes, 28seconds
computer B:
CPU: 800MHz Pentium III
number of CPUs: 2
RAM: 1024MB
time: 17minutes, 15seconds
[ May 24, 2002, 11:42 AM: Message edited by: adrian_dav ]
Guest adrian_dav
computer C:
CPU: 1800+ Athlon MP
number of CPUs: 2
RAM: 3000MB
motherboard: Tyan Tiger MP
time: 10minutes, 3seconds
Guest adrian_dav
computer C using only 1 CPU:
number of CPUs: 1 (second CPU disabled in taskmanager)
RAM: 3000MB
time: 17minutes, 2seconds
Guest adrian_dav
computer A using only 1 CPU:
RAM: 1024MB
time: 24minutes, 36seconds
computer B using only 1 CPU:
RAM: 1024MB
time: 31minutes, 14seconds
Pentium 1.8A Northwood
WinBlows 98 SE
Viz 4
Asus P4B266-C
512 megs of PC3000 Mushkin DDR.
Memory settings to 2-2-2 and 4 way interleaving
Geforce 4 Ti 4400 (Software heidi used)
17 Minutes 59 Seconds
I'm not entirely sure if I did this correctly, so I'll be running it again. I think I just rendered in which case its the radiosity + the render itself. So now I'm just using the radiosity panel to compute the time.
Guest adrian_dav
very very impressive speed. the rendering should have added something like 20 seconds. it seems that radiosity just scales well with the MHz and doesn't use the FPU-heavy features that are very strong on the athlon.
you might be rightin the other thread and i'm fine with just 2 xeons.
thanks for running the solution.
Note that the 1800+ XP (a 1.53 Gigahertz Athlon) Beats the 1.8A Northwood in this particular test.
Even with the Pentium IV's almost 300 megahertz speed advantage, I think the powerful FPU of the Athlon is still dominating, making it the superior choice over the Pentium IV based systems.
I'm curious to see if anyone has a Dual Tualatin system to benchmark.
AMD Athlon 2000+ (1.66 GHZ)
Windows XP Pro
Viz 4
IWILL XP-333-R rev 2.1
768 megs of PC3000 OCZ DDR.
Elsa Gloria III (Quadro II) (Software Maxtreme used)
Radiosity time:
15 Minutes 16 Seconds
Render Time:
0 Minutes 12 Seconds
[ May 24, 2002, 11:44 PM: Message edited by: CHE ]
These results alre realy shocking me!
I'm going to buy myself a new PC this summer, and I allways thought that for stuff like VIZ4 I deffinately needed to go for the Intel Pentium IV !
But it seems that AMD is the better choice.
And with AMD I can maybe afford a dual CPU system :)
Guest adrian_dav
intel seems to be close behind amd when it comes to calculating radiosity at the same clock speed. nobody posted results for a p4 xeon 2.4GHz yet, but i assume it runs circles around the athlon MP 1670MHz(or 2000+ PR rating).
that would be a relief for me. i use a dual athlon system right now. it runs very hot and needs a lot of cooling resulting in nasty noice levels. no more amd chipset on my mobo please! i'd like working USB, shutdown windows despite the existence of a firewire card, less heat and more predictable RAM support.
it might have been just my tyan MP board, but it felt like an unfinished product from the beginning.
Guest adrian_dav
Originally posted by Greg Hess:
If someone posts the 2.4 Xeon. I'll post a Dual 2100+ MP and make them weep. :)
The higher intel goes, the faster amd catches up :).
And yes I'm biased. My 1.8A northwood is slow as !@$(*7 compared to my AMD system.
the little chip war is the best thing that ever happened to us. i'm biased in both directions. i like AMD's raw FPU power and i like intel for being able to build a box that doesn't sound like a vacuum cleaner.
since i spent looooong hours near my machine the noise is a bit of an issue. at least i don't hear the airconditioner as much :). do things get better with the new athlons?
Noise is a problem regardless of which chip you go with. To solve either problem you need to do some research, and setup the cooling yourself. If your willing to do that, you can build dual systems with well under 35 db output. (Thats with 8 fans).
Currently my default 1.8A Northwood is AS LOUD as my dual 1900+ MP system.
So don't think that buying intel you automatically solve the noise problem :). YOU have to solve the noise problem, AMD and Intel don't care :).
I commented alot on this issue in one of the other dual athlon threads on this forum about jeff's system. The easiest solution is replacing all the fan's in the case. Throw in some adjustable rpm fans, and you can tweak the noise levels and get the same quiet ambient hum throughout. This of course requires massive heatsinks on the cpu's, as you need to cool more with surface air then airflow.
If noise is still a problem, there are a variety of insulators you can purchase to cut off front and top and side noise. I would recommend if you do this, to greatly increase the ventilation out of the rear of the case, to help hot air escape. Insulation also creates heatbuildup and nullifies all the advantages (cooling wise) of an alumnium case.
The most advanced and technically challenging setup would be a water cooling system, contained within an insulated box, with an external resevoir and monitoring system to completely remove any and all fan sounds from the case area.
The new AMD systems now include a downclocking system to reduce core temperature, just like intel has with the p4's. With the burning up problem solved, I really don't seen any reason going with an intel solution, unless your forced too, or have a specific program that utilizes SSE2.
Probably the quietest system you could build WITHOUT rpm adjustable fans would be...
A case using an enermax whispher powersupply, with 4 x pablst 16 CFM fans (18 db), with two silverrado's (around 60 USD each) as cpu coolers.
That would then make the loudest part of the computer the rom and hd's.
  • 1 month later...
  • 4 weeks later...
Guest adrian_dav
Originally posted by matt_vinoir:
hmmm adrian had 3 gig of ram for 6 sec quicker time, gutted!!
the amount of ram does not have any influence on the time needed in this case. it is a small scnene even after viz is done "meshing" it. more ram would be useful for a large scene to avoid swapping data back'n'forth between memory and hard drive.
i just don't have the time to take the ram out of the box each time i render a small scene :).
best,
a
Guest adrian_dav
i'm not rubbing it in adrian! I'm just amazed, as all you here is viz will eat all the ram you can chuck at it in evrey circumstance, i didn't realise it wasn't the case all ther time
... and i didn't intend to come across as one of these "mine-is-bigger-than-yours RAM-machos" :). the RAM requirements of viz4's radiosity process are imense. autodesk should advertize VIZ to consumers by having put RAM-sticks put into cherio boxes :).
i always considered 1gig RAM overkill, but a typical rendering size of 4000x3000pixel in conjunction with the RAM-eating radiosity solution made it neccessary to get more.
greg_hess mentioned in another thread on this forum that windows is limited to 2gb RAM per thread anyway. not much room to expand :-(. we better watch the polys and skip the chamfer and fillet tools from time to time :).
best,
adrian
Guest coupe333
Win XP pro
Dual AMD 1800mp
MB: asus A7M266-D
Ram: 1G
Vga: GeForce 500 Ti
Radiosity Time: 0:10:05
Rendering Time: 0:00:13
