rayray Posted March 11, 2005 Share Posted March 11, 2005 When I export an autocad drawing into photoshop by converting it first to an .eps file it takes forever. A 3 Mb autocad (.eps) drawing of 300 dpi, takes about 15 minutes to open in photoshop if I’m lucky and the computer doesn’t jam. Isn’t there a faster or easier way to import .eps files into photoshop? Would, making the file size smaller help? Link to comment Share on other sites More sharing options...
DennisHolland Posted March 11, 2005 Share Posted March 11, 2005 Hi Rayray, making your files smaller is really the only way. Why not? You're dealing with vectorfiles here so it doesn't make a difference what size you have 'm, they are always the same quality. Unlike pixels (jpg, tif etc) vectorfiles are not influenced by sizes and/or resolution. Do yourself and your computer a favor and resize 'm. Looking at the amount of mb's and loadingtime, I guess...you can reduce it all at least 80%. Good luck, Dennis Link to comment Share on other sites More sharing options...
xelan Posted March 11, 2005 Share Posted March 11, 2005 Hi Rayray, making your files smaller is really the only way. Why not? You're dealing with vectorfiles here so it doesn't make a difference what size you have 'm, they are always the same quality. Unlike pixels (jpg, tif etc) vectorfiles are not influenced by sizes and/or resolution. Do yourself and your computer a favor and resize 'm. Looking at the amount of mb's and loadingtime, I guess...you can reduce it all at least 80%. Good luck, Dennis The question was I assume referring to rasterization of .eps files. So rasterization time also depend on the given resolution. I don't know any faster way, however 15 min is not something I'd worry about. Link to comment Share on other sites More sharing options...
VincentVega Posted March 16, 2005 Share Posted March 16, 2005 Hi Rayray, making your files smaller is really the only way. Why not? You're dealing with vectorfiles here so it doesn't make a difference what size you have 'm, they are always the same quality. Unlike pixels (jpg, tif etc) vectorfiles are not influenced by sizes and/or resolution. Do yourself and your computer a favor and resize 'm. Looking at the amount of mb's and loadingtime, I guess...you can reduce it all at least 80%. Good luck, Dennis But when you open a vectorfile like EPS it will transform to a pixelbased form or am I wrong? Photoshop isn't a vectorprogram, so it looks to me that if you open a small vectorfile it will be blurry when you zoom in, or isn't it? Link to comment Share on other sites More sharing options...
Jason Matthews Posted March 17, 2005 Share Posted March 17, 2005 But when you open a vectorfile like EPS it will transform to a pixelbased form or am I wrong? Photoshop isn't a vectorprogram, so it looks to me that if you open a small vectorfile it will be blurry when you zoom in, or isn't it? This is very true. When printed to an eps in CAD, this takes the vector format and turns it into a semi-raster format. It is semi-raster because you can tell phootshop to raise or lower the resolution. The higher the res the better the pixels, obviously. If comp is takeing forever to open the file, you need more RAM. I have a 3.0 GHZ P4 and 2 GB RAM and it never takes too long to open an eps file in PS. And I have had 80 MB 3D CAD files. Jason Link to comment Share on other sites More sharing options...
3dQ Posted April 4, 2005 Share Posted April 4, 2005 This is very true. When printed to an eps in CAD, this takes the vector format and turns it into a semi-raster format. It is semi-raster because you can tell phootshop to raise or lower the resolution. The higher the res the better the pixels, obviously. If comp is takeing forever to open the file, you need more RAM. I have a 3.0 GHZ P4 and 2 GB RAM and it never takes too long to open an eps file in PS. And I have had 80 MB 3D CAD files. Jason right...so the solution to this is to upgrade....but if you cant, well, open your autocad drawing and press Print Screen on your keyboard to put your screen image on the clipboard.....then on photoshop, click file>new, when asked about the canvas size dont change the settings, just click ok, then simply paste the image on the clipboard to your canvas....if your using any Windows OS, it might just work.... Link to comment Share on other sites More sharing options...
Bugga_Guy Posted April 4, 2005 Share Posted April 4, 2005 Why not make a PDF, and open that in photoshop instead? Link to comment Share on other sites More sharing options...
4CGFX Posted April 5, 2005 Share Posted April 5, 2005 Why not make a PDF, and open that in photoshop instead? its originally an eps, i think you can turn it to PDF with ps, but since hes having trouble opening it to ps, can you suggest another way of doing it? Link to comment Share on other sites More sharing options...
Bugga_Guy Posted April 5, 2005 Share Posted April 5, 2005 Why go throught all that headache. bypass eps and go straight to PDF Using Autocad, Plot the drawing to a PDF using acrobat distiller instead of a plotter or printer. Takes like 2 seconds to make. Then open in Photoshop. Just make sure if you want high quailty to export at a A0 size or something. Link to comment Share on other sites More sharing options...
gantsa Posted April 11, 2011 Share Posted April 11, 2011 I was about to import an EPS file(from acad) to photoshop. The plan is going to be finaly printed in 1m x 2m paper and contains lots of details. I was wondering if i should rasterize it in 300 pix/inch when i will import it into photoshop for the first time. (or something like 150 would be enough?) I run it into a PC with 64 bit AMD - 3 GB DDR3 ram Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted April 16, 2011 Share Posted April 16, 2011 Two things to consider: How big is a "detail" in the final print? How far away from will it be viewed? Link to comment Share on other sites More sharing options...
