Glass in max 7
Sketchrender
I am having some trouble getting glass to look right in max 7.
What material should i use to get the right effect of glass i presume it is a raytrace and then what ?
Can some body post a material from max file as sometimes it is the only way to see how things are made.
thanks
phil
i've been staying away from the arch materials...i use a raytrace map, phong shader with a falloff in the reflect slot, then apply a raytrace map into the top slot of the falloff with frensel falloff override ior @ 1.5, set the color of the diffuse to a greyish and the transparency to 65-75%, self illum to black...thats for exterior scenes
Even more simple,
pick a raytrace material, specular -> 250, glossiness -> 85, falloff (fresnel) in the reflectionslot change the refl. to 75, index of refr. to 1.35 and transparency set to a level of your desire, I mostly set it to 85-90%.
Use these settings as a reference and play around a bit. Glass is a tricky material and is acting different in every other scene.
You'll end up having yourself a standard, clean and wholesome piece of glass. A suggestion would be to make the glasscolour deepdarkgreen...
Good luck,
Dennis
