treddi Posted March 14, 2005 Share Posted March 14, 2005 First of all I would thank you for your help. I am a 3dsmax beginner so pardon me if I ask something that is obvious for you. What I want to obtain is showed in the image attached: a reflection on the ground that smoothly disappears in a white ambient (I made the attached example with photoshop). Can you kindly explain to me how to do that with 3dsmax with a plane and a box? Thank you again for your patience. Treddi Link to comment Share on other sites More sharing options...
DennisHolland Posted March 14, 2005 Share Posted March 14, 2005 Hi there, Don't bother asking around, it's saves you a lot of aggrevation, especially when your just turned to MAX.... the easiest way is to (hit m) and pick a raytrace-material in materialbrowser, turn on 'reflections' and adjust the settings in your maps rollout (0 = no refl. 100 = ultra refl.). You should surf the tuts at http://www.3dcafe.com for learning the basics. Good luck, Dennis Link to comment Share on other sites More sharing options...
treddi Posted March 14, 2005 Author Share Posted March 14, 2005 Dennis, thank you very much: I'll try now. Link to comment Share on other sites More sharing options...
manta Posted March 14, 2005 Share Posted March 14, 2005 add a gradient to you reflection Link to comment Share on other sites More sharing options...
manta Posted March 14, 2005 Share Posted March 14, 2005 like this... Link to comment Share on other sites More sharing options...
