Richard McCarthy Posted March 16, 2005 Share Posted March 16, 2005 Hi, just wondering does anyone know how to make the max interface look more like VIZ4? Link to comment Share on other sites More sharing options...
Richard McCarthy Posted March 17, 2005 Author Share Posted March 17, 2005 Found it ! http://www.cgtalk.com/showthread.php?t=198733 Link to comment Share on other sites More sharing options...
Elliot Posted March 17, 2005 Share Posted March 17, 2005 Richard, I can't open the file on CG Talk. Could you send me a copy. Thanks Elliot Link to comment Share on other sites More sharing options...
Richard McCarthy Posted March 17, 2005 Author Share Posted March 17, 2005 Hi Elliot, To open the file in MAX, it's quite simple, MAX by default only open *.ui file. To open the *.cui file, goto : customize > load custom ui scheme On the "files of type" scroll down list, "change it to ui files (*.cui)" and load the file you just downloaded in the max root/ui directory. Link to comment Share on other sites More sharing options...
Elliot Posted March 17, 2005 Share Posted March 17, 2005 Richard, Thanks for the information. However, that's not the problem I having. The problem I have is that the ZIP file on the web site will not open. It gives me a message saying it is corrupted. I think other people on their site are also complaining about the same issue. What I need is the actual zip to place it on my directory. Thanks Elliot Link to comment Share on other sites More sharing options...
Richard McCarthy Posted March 17, 2005 Author Share Posted March 17, 2005 Sorry I misunderstood your question Elliot, Here is the file : Link to comment Share on other sites More sharing options...
Elliot Posted March 17, 2005 Share Posted March 17, 2005 Richard, Perfect..... it works...! Thank you very much Elliot Do you know if V6 or V2006 is going to be like Viz 4....? Link to comment Share on other sites More sharing options...
Richard McCarthy Posted March 17, 2005 Author Share Posted March 17, 2005 You mean VIZ2006? I have no idea mate. I am not on Autodesk Beta tester list LOL. Link to comment Share on other sites More sharing options...
Elliot Posted March 17, 2005 Share Posted March 17, 2005 Richard, It is not a beta, It has already being offically anounced. Elliot Link to comment Share on other sites More sharing options...
Richard McCarthy Posted March 19, 2005 Author Share Posted March 19, 2005 Yeh I know, I seen in the topic, but I havn't personally seen VIZ2006. I presume it will look the same as VIZ4 with some added minor function update and bug fix (autodesk love to do these kinda thing ) Link to comment Share on other sites More sharing options...
Elliot Posted March 19, 2005 Share Posted March 19, 2005 Richard, Thanks for the response. I loaded the file you sent on the correct directory but when I try to open it from V2005 it says this Files is not compatible with this version. See you Elliot Link to comment Share on other sites More sharing options...
Richard McCarthy Posted March 20, 2005 Author Share Posted March 20, 2005 I don't know this file will work with VIZ, it's meant to only work for MAX 6 and 7 I think... Link to comment Share on other sites More sharing options...
Elliot Posted March 20, 2005 Share Posted March 20, 2005 Richard, That must be it... I have tried and it doesn't want to work. Thanks Elliot Link to comment Share on other sites More sharing options...
