VCRUPI Posted March 17, 2005 Share Posted March 17, 2005 Hi all, I was wondering if anyone using 3ds max 7 with Brazil r/s 1.2 may know of a way to distort a camera to make a house look longer...i have been playing with the perspective for the camera...but it only gives depth, where i need width. Here is my dilema...i have a house with a side garage and want to show the front of the house primarily, but the garage must also be visible. I know this technique is used when hand rendering homes (distortion, streching) but not quite sure how this would be manipulated in 3d. One more thing, i cannot use any fisheye lenses either, the house must not be distorted to that extreme. Link to comment Share on other sites More sharing options...
pmanahan Posted March 17, 2005 Share Posted March 17, 2005 In max I have used a small lense like 24, which distorts the view quite a bit and then I applied a deformer like skew, or try another dformer, to the camera and then skewed it back to normal. Some trial and error involved. pmanahan Link to comment Share on other sites More sharing options...
William Alexander Posted March 17, 2005 Share Posted March 17, 2005 You may want to try a wide angle lens, 24mm-18mm or less. 75-90 degree FOV. Then apply the Camera Correction Modifer to "undistort" or correct the excessive paralax. That typically can create the "architectural" style feeling. WDA Link to comment Share on other sites More sharing options...
JamesTaylor Posted March 18, 2005 Share Posted March 18, 2005 Are these the camera settings that you would suggest for internal views as well wda? I have always felt that the spaces i create for internal appear smaller than they are in reality - have been testing by modeling existing rooms. I appreciate that our eye has a much wider field of view than a camera can achieve but compared to other renders i see i always strugle to create a sense of space Link to comment Share on other sites More sharing options...
VCRUPI Posted March 18, 2005 Author Share Posted March 18, 2005 thanks for the responses... Link to comment Share on other sites More sharing options...
