spoudastis Posted March 21, 2005 Share Posted March 21, 2005 can anyone tell me how i can make my colors go where i want them to? i have a small interior scene with green walls, with the settings the way they are now in vray the whole scene is overwhelmed by green. how can i make just the walls green with the minimal green color bleed that would occur naturaly? thanks in advance. Link to comment Share on other sites More sharing options...
JamesTaylor Posted March 21, 2005 Share Posted March 21, 2005 if you reduce the saturation parameter in the indirect illumination section of the render dialog box it should reduce the colour bleed Link to comment Share on other sites More sharing options...
JamesTaylor Posted March 21, 2005 Share Posted March 21, 2005 the saturation can also be changed on an per object basis i believe so individual elements can be controlled Link to comment Share on other sites More sharing options...
evanmoses Posted March 21, 2005 Share Posted March 21, 2005 go to vray:system, object settings, select the offending walls and then reduce the multiplier for generate and receive GI. Link to comment Share on other sites More sharing options...
BrianKitts Posted March 21, 2005 Share Posted March 21, 2005 Your other option would be to go into your material editor, select the material that's bleeding. And for material type select "Arcitectural Lighting Override", after selecting it, select "keep original as a sub-map". That will keep your original material settings, and now with the lighting override you can turn down the color bleed setting for just that material. Link to comment Share on other sites More sharing options...
spoudastis Posted March 21, 2005 Author Share Posted March 21, 2005 thank you all for your replies, very helpful. Link to comment Share on other sites More sharing options...
