model scale
You can't fool a render engine.
It would still have to process the same number of faces and how they react to each light in the scene.
The scale size of the model won't affect this.
What you have to do is reduce your polygon count or optimise the scene in other ways.
  carlos cristerna said:
thats what I though, but since some of the renderers like mental ray and Vray do take in count image size for some of the parameters well, I just give it a thought, I will run a test tonight and tell you tomorrow what happened.
yes, image size is a factor, as well as the parameters you set i the render dialog. some renders you have to set the distance at wich things are taken into the which things are taken into the rendering solution. but... scaling your model down will not work. if you scale it down, you will need to set your parameters a little finer, and in zoom in closer, negating the scaled down factor.
listen to IC and STRAT. they are have a lot experience, and know what they are talking about.
if you want to improve your render times, post what render engine, andyour parameters you are using. some out there will know how you can tweak them to speed things up.
