brvitorino Posted March 23, 2005 Share Posted March 23, 2005 Hy guys, I´m a new Vray user and I´m still trying it, so I´m having some difficults. Does anybody knows why this rendering was so hard? I used an Athlon xp 2.13GHZ 1GB RAM and the rendering process was so slow. Image size 3189 X 2362 Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted March 23, 2005 Share Posted March 23, 2005 read about irradiance maps. Link to comment Share on other sites More sharing options...
Alicja Posted March 23, 2005 Share Posted March 23, 2005 Hi, try to with: AA:Adapt.subdiv:1;2 GI:Hsp50, Dir Comp.10;3 Color mapping:Exp. 3;1 and use directional light, I think will be better, Alicja Link to comment Share on other sites More sharing options...
Fran Posted March 23, 2005 Share Posted March 23, 2005 Hi Bruno, Here is another friendly answer for you. What are the settings for your Vray lights? Are they set as portals? That can increase render time. Also, glossy reflection and refraction can slow things down - is there any of that in there? Also, isn't 10 an extremely high setting for dir comp. subdivs? I've never gone above 3 and even with the preset quality of Very High the dir comp values are only 1:3. Care to show us the final render? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted March 23, 2005 Share Posted March 23, 2005 read about irradiance maps. i guess i should explain a little. are you rendering an irradiance map at a lower resolution, or are you trying to render an irradiance map at the final image resolution? Link to comment Share on other sites More sharing options...
Christopher Nichols Posted March 24, 2005 Share Posted March 24, 2005 You also seem to be using a LOT of area Vray lights... If you are, even just using area Vray Shadows, try setting all the shadow settings to "Store With Irradiance Map" This will really speed up things, but only if you are doing an Irradiance map, which you are. Link to comment Share on other sites More sharing options...
brvitorino Posted March 24, 2005 Author Share Posted March 24, 2005 Hy everyone, travis,once i tried an irradiance map at a lower resolution, but result was not good; Alicja, thank you I´m gonna try your set up; Fran, thank you, you are so sweet Here are the final images Link to comment Share on other sites More sharing options...
Alicja Posted March 24, 2005 Share Posted March 24, 2005 I think it's look better, but you should add bump on the floor and try to use variety lights . Link to comment Share on other sites More sharing options...
mak_designs Posted March 25, 2005 Share Posted March 25, 2005 21:41:01? that is scary, well as they say, Rome was not built in a day, so don't worry, it all has to do with dimension size also, 3189 X 2362 is pretty big, so its a given to expect a long render timeframe... Link to comment Share on other sites More sharing options...
