Living room - please comment
wsneto
to me the lighting is too even. i'm not sure if its a viz 4 thing, but it seems that everything is getting a lot of light, maybe from omni's? what does your lighting setup look like?
other than that, i'd remap the door frame so the grain runs horizontally at the top, vertically elsewhere, and lose the plant. the wood texture itself seems a bit too much as well. it's very rich.
what's going on with that TV? i don't understand what that map is suppose to be.
the wall on the right looks good with those spots though.
its a good start, keep going.
chuck
Lighting is too even. Check the ambient levels (I am not familiar with radiosity in viz) or the omni's chuck pointed out. That's the largest concern. It needs contrast to bring it to life. I'd turn off whatever is making it uniform and start from there.
Good start, it'll be very nice once you nail that down.
Hi there "wsneto"!
I agree the lighting is to uniform and to bright.
I would also change the two downlights/spots aimed at the painting to a single wider spot or aim one of the to spots more center at the painting.
The TV problem is probably related to a too big mesh and high filtering.
Colours are great! Maybe to dark/saturated doors
