alekzab Posted March 25, 2005 Share Posted March 25, 2005 im new with vray, im currently using the demo version,. i am satisfied with the shadows at this moment in time, but does anyone know why im I getting that the "material returned overbright or invalid color" causing the matrials to be washed out. Link to comment Share on other sites More sharing options...
Chad Warner Posted March 25, 2005 Share Posted March 25, 2005 Check UVW mapping, specular levels of materials, and that any bitmaps have the "crop" option checked, regardless of whether or not they actually are cropped. Link to comment Share on other sites More sharing options...
Sawyer Posted March 25, 2005 Share Posted March 25, 2005 Also make sure you only use vray materials. Link to comment Share on other sites More sharing options...
alekzab Posted March 25, 2005 Author Share Posted March 25, 2005 thanks sawyer, but where does one get vray materials? and does the renderer allow you create you own maps? Link to comment Share on other sites More sharing options...
Sawyer Posted March 25, 2005 Share Posted March 25, 2005 Well vray mats may belong to the advanced feature set. try a rendering with a lt gray material. add 1 mat at a time and see if you can isolate the material if its materials (usually is imho) that are causing your problems. Also turn off all raytace maps. Link to comment Share on other sites More sharing options...
ps Posted March 26, 2005 Share Posted March 26, 2005 hello , in 3ds or viz rendering=» enviorenement and effects=» exposure control , set to « no exposure control». Link to comment Share on other sites More sharing options...
bobsan Posted March 27, 2005 Share Posted March 27, 2005 You might also want to try vray shadows on your lights. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted March 28, 2005 Share Posted March 28, 2005 im new with vray, im currently using the demo version,. i am satisfied with the shadows at this moment in time, but does anyone know why im I getting that the "material returned overbright or invalid color" causing the matrials to be washed out. Please, post renderer-related messages on the Third Party Renderers Forum. Link to comment Share on other sites More sharing options...
Jim Mann Posted March 28, 2005 Share Posted March 28, 2005 The Farnsworth house gets extended huh!?! All the advice you are getting is good. Change all your materials to Vray materials, use Vray lights, use vray shadows, switch off any Max exposure control, set your maps to "apply crop".You can convert a scene to a VRAY scene from the quads menu (right click) What does it look like if you only light the scene using the skylight? My first test though would be to try the direct light with a multiplier of 1 rather 2.5 JM Link to comment Share on other sites More sharing options...
tuekappel Posted April 3, 2005 Share Posted April 3, 2005 also try to set the color mapping type to exponential. this won't get rid of the error message, but it will remove your over-bright spots Link to comment Share on other sites More sharing options...
