Boxx Work Station
Though I'm slightly biased...
The Boxx system is the one of the best systems I've ever worked with. Its almost silent, its unbelievably fast, and hasn't even had a hiccup stability wise in over a month of near constant rendering.
Worth every last cent.
Boxx makes workstations.
Dell makes desktops, throws in more ram and a professional video card, and "calls" them workstations.
The only way I've gotten our dell workstations stable, is through...
1) One motherboard replacement. (Dell)
2) Two dimm replacements. (Kept getting bad replacements)
3) Cooling system overhaul. (Artic Silver + Higher RPM fans)
Maybe I've just had horribly bad luck again and again. Maybe the University's Dell rep's are just aholes.
Feel free to check the other thread in this forum... which discussing some issues more in detail.
Feel free to comment on them as well David.
http://www.cgarchitect.com/ubb/ultimatebb.php?ubb=get_topic;f=2;t=000143;p=1
I'm with David on this one... During my stay at Gensler (from 1998 to 2002), I have had nothing but Dell workstations. During rotations (lease plus upgrade) I must have used 10 different workstations. The only one we had problems with was the one that we had to rig to work with our video editor... not Dells fault, but DPS's fault. The workstations were stable fast a quiet. Custumer service was amazing... something like 24 hours on WS, and 4 hours on servers (if needed). Probably because Gensler leasted over 2000 computer from them.
Not to say that Boxx MAY be a better computer. They are made by 3D people FOR 3D people... sorta like that tampon commercial.
I just think that your experience with Dell is based on bad luck Greg... I hate that.
My Dell laptop has been great except for the typical laptop issue of not being able to upgrade the CPU and video chip to better models as they appeared. I even got them to put W2K on it.
I did just recently buy a Boxx box and it has been working hard constantly (CPU pinned at 100% for days at a time) doing light calc and raytracing frames. It has been doing just fine. It does have a problem with writing to the ZIP drive, but I called Boxx and they over-nighted me a replacement. They also delivered the machine in a big hurry so i could get a big job rendered. I REALLY appreciated that.
Lightscape is having a stability problem with regard to texture handling so I know its a driver issue--of which there will be more and more as LS gets older and older.
To sum up, I can say I am very happy with the Boxx machine, and the Boxx company.
Hello
Well, I saw many workstation here the most of them was from DEC, Compaq and HP.
Mostly if a system crashing, there was a user failure/caused (Yes, Greg)!
And the differences between the speed are not relevant, since there is only a couple of percents (that the boxx is much faster than dell is a bulls...).
One thing maybe you should really consider: The NOISE it's coming from the system.
We selled many systems, and not ONE is comed back bacause of some defect.
Also not one their are coming from DEC, Compaq or HP.
Richie
You should use Vray, then it won't have to work so hard all the time....
That is a distinct possibility. I see the fairly near future holding for me a migration to either MAX/Vray (based mostly on your ravings, Chris) or Cinema4D. As much as I love using Lightscape, it is going to become increasingly hard to do 'modern' work with it. Although I am curious about how fast the Vray raytracer is vs. the command-line raytracer in LS. Any thoughts on that?
Hi all...
I use Boxx systems at my studio. So far we have purchased 2 of them... one more soon. I looked over a number of places before buying (including Dell). When I spec'd out machines at Boxx vs. machines at Dell with as close as possible spec's Boxx had the price advantage.(at that time anyway). When I called Boxx I got the same rep everytime..he new his stuff, and returned my calls. I had some very technical questions for him because I use Newtek's Toaster 2. He knew exactly what I was talking about and we configured the machine..it came without a single glitch. I would recomend them to anyone looking for a new workstation. I see alot of people getting stuck on brandnames or "safe" or "it's what everybody else is using" solutions (software and hardware). It's one of those things that you don't know what your missing unless you step outside of the current mindset. Just my little 2 cents worth. :D
