ecastillor Posted March 31, 2005 Share Posted March 31, 2005 Does anybody know of a good road texture tutorial? I have a lot of different straight roads, but in many cases i cant use them because there area curved streets and what not.... How do I achieve that worn reaistic look for mi roads? Thanx! Link to comment Share on other sites More sharing options...
3dQ Posted April 4, 2005 Share Posted April 4, 2005 here you go: http://falcon4.nekromantix.com/docs/zaggy_tile_tut.php hope it helps... Link to comment Share on other sites More sharing options...
4CGFX Posted April 5, 2005 Share Posted April 5, 2005 learn from this: http://www.ambientlight.co.uk/textures/roadgen/ looks good to me.. Link to comment Share on other sites More sharing options...
doodler Posted April 19, 2005 Share Posted April 19, 2005 why not go and shoot some road yourself? then you can get the correct angle lighting etc as you proposed scene Link to comment Share on other sites More sharing options...
BpOx Posted April 29, 2005 Share Posted April 29, 2005 why not go and shoot some road yourself? then you can get the correct angle lighting etc as you proposed scene hey...thats a pretty good idea...theres nothing like the real thing...i guess this will work well for almost any object that we usually see everyday. Link to comment Share on other sites More sharing options...
vkirchner Posted November 4, 2005 Share Posted November 4, 2005 Thank you for the tutorial, but I would like to ask for assistance with a greater level of detail with respect to the road lines. I am trying to generate a highly detailed city driving animation to be used for an optical simulation. The problem I am having is how to paint road lines accurately, keeping the spacing correct as the road curves and also along ramps and exits. Can you suggest options for this? I have been trying to use vector based curves inside Photoshop CS. Regards Vince (Newbie) Link to comment Share on other sites More sharing options...
piotrgreg Posted November 6, 2005 Share Posted November 6, 2005 I had same problem once i just modeled the separate regions for curved lines and then put the procedural map on it to preserve the right b-w spacing - refer to some Ted Boardman tutorial on the main cg page good luck Link to comment Share on other sites More sharing options...
AJLynn Posted November 7, 2005 Share Posted November 7, 2005 I usually do that with geometry, it's pretty simple in Sketchup or Autocad or whatever to model the white dashed lines as maybe 1/8" extruded bits, then you can put a white paint texture on it with procedural bump and specular. If you want to do it in PShop... I forget how good CS's tools for this are but in Illustrator you can make the pattern using a simple dashed line with dash and space length defined, and apply it to a path. If you have Illustrator it's actually got some good procedural texture making features, you can make the diffuse, bump and specular from the same file. Link to comment Share on other sites More sharing options...
vkirchner Posted November 7, 2005 Share Posted November 7, 2005 Unfortunately I do not have a copy of Illustrator available, I will have to fall back onto our cad systems for that. I have been trying to build specific brushes within Photoshop that will mimic the lines and spacing, but without too much luck. Probably my skill set is too limiting at this point. I had hoped to do a US and European set of road sets, but that will take some time to model the correct spacings of a very large track, and recently the Boss also asked for a Japanese version of the track. The hits just keep on coming, so I will look for the tutorial you mentioned. Thank You Vince Link to comment Share on other sites More sharing options...
