jvlive Posted April 1, 2005 Share Posted April 1, 2005 i've recently tried to implement network rendering in the office. at first it worked, then after like 3 renders it fails when i send to others pc's. here's the pic: i work on my pc then i have 2 slaves. i run server on all, manager and monitor on mine. the jobs get sent successfully, but when they're almost done on the slaves i get an error message saying : SERVER XXX FLAGGED AS ERROR AS IT TOOK TOO LONG TO PROCESS TASK ERROR MESSAGE: TASK TIMEOUT (50 MINS) then it repeats the render from the start..... INF SERVERXXX CLEARED AGAIN FOR (JOB) (RETRY#1) then i get the error message.... ERR CANNOT CREATE A FILE WHEN THAT FILE ALREADY EXISTS. (0XB7) then it repeats the render again and again. i figure maybe after its 1st try backburner creates a file so that in the 2nd try it thinks it already exists! i dunno, im a noob in this. whats funny is that when a job is sent to my pc it saves the render normally. need help please. thanks much. Link to comment Share on other sites More sharing options...
JamesTaylor Posted April 1, 2005 Share Posted April 1, 2005 not entirely sure how to fix it but the time out error is just a setting - i think the idea is so you could leave a series of renders over a long period say a weekend, and wouldn't have to worry to much about it crashing and then rendering nothing. If a render takes longer than the set time it will restart as it thinks it has crashed - overcome this error by locating the time out setting network rendering manager screen. sorry to be vague, i don't know the ins and out of the network rendering 100% but use it quite a bit at work, hope this helps. Link to comment Share on other sites More sharing options...
jvlive Posted April 1, 2005 Author Share Posted April 1, 2005 thanks james. i saw some threads on this just now, so i figured how to adjust the render timeout. ... and as i am typing, just got my 1st completed render from a slave. yipee! thanks to all those who helped on the other similar threads too. Link to comment Share on other sites More sharing options...
anvaraziz Posted April 2, 2005 Share Posted April 2, 2005 hey can u share how u fixed it ,, i too have the same prob:... thanks Link to comment Share on other sites More sharing options...
jvlive Posted April 3, 2005 Author Share Posted April 3, 2005 as i've read in the other posts..... in the queue monitor right click on the job, then go to edit settings... a job settings window will come up, scroll down to timeouts then adjust the "wait to render" to a higher number (in mins., default is 50). i guess the job i sent required more than 50mins to render so i set it to 120. it was a success after that. hope this helped you. Link to comment Share on other sites More sharing options...
