mark68 Posted April 1, 2005 Share Posted April 1, 2005 Where are the hatch pattern files kept? I downloaded a hatch pattern and want to add it to the default list. I want it available in my hatch patten drop down box. thanks Mark Link to comment Share on other sites More sharing options...
mtb0506 Posted April 2, 2005 Share Posted April 2, 2005 Mark, what software are you using? i'm going to assume its autocad. in that case the hatch patterns go in the "support" folder. the default is C:\Program Files\Autocad(whichever version)\support. Link to comment Share on other sites More sharing options...
mark68 Posted April 4, 2005 Author Share Posted April 4, 2005 I dragged the file to the support folder but i noticed it is a drawing file. What type of file should it be? I can't find it in my drop down box when I hatch an object. Any suggestions? thanks Eddie Link to comment Share on other sites More sharing options...
BenWilson Posted May 5, 2009 Share Posted May 5, 2009 go to c:\Documents and Settings\(your username)\Application Data\Autodesk\(AutoCAD or LT version)\enu\support you then need to add your new hatch data to the end of files (open in notepad):- acad.pat acadiso.pat make sure you save both as the original file extension, not .txt like notepad will want you to. your new hatches should now be in with the rest when you open up autocad. Link to comment Share on other sites More sharing options...
