raterry Posted April 4, 2005 Share Posted April 4, 2005 Has anyone experienced this? If I apply any kind of Raytrace map to a material and have the background turned on in the slot, the sample material becomes invisible no matter the settings, Only way to make is visible again is to copy a "None" map to replace raytrace. It has no affect on the material itself just the sample in the slot. I have a bunch of different materials with raytraced reflections but I can't easily identify which material is which in the M.E. because they all look like this: see attached. Any ideas or solutions? Thanks, -=Rob Link to comment Share on other sites More sharing options...
quizzy Posted April 4, 2005 Share Posted April 4, 2005 you might want to check the checkbox in front of the raytrace mapping... Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted September 28, 2005 Share Posted September 28, 2005 i'm not sure, but go to render dialog, raytracer tab, and check "enable raytracing", maybe you unchecked it inadvertedly. if it's not that, i dunno what it could be... Link to comment Share on other sites More sharing options...
