frame aspect ratio for NTSC broadcast
edub
I need to render out an image sequence to be comped for DVD.
I've been told that I need the 720x486 D1 frame aspect ratio, but since my animation is set up for 16:9 AR (originally 640x360) I am confused how this is to be accomplished.
Do I need render out in 864x486 (16:9), and then squash it to 720x486, which will then look correct once it's made into DVD?
I've had this explained to me a couple of times already, but I can't seem to understand the underlying concept.
Does someone know of a good reference for this? Or can someone explain this to me in simple steps?
I would really appreciate this. Thanks
ok, after a bit more research I've come to the conclusion that I have to render at 720x486 w/ a PAR of 1.2.
This will then be shown as the correct 16:9 FAR of 864x486 on the DVD.
can anyone back me up on this one?
Thanks in advance
  Bugga_Guy said:
I highly recommend 720x480 for widescreen not 728x486!!!
any particular reason?
would it possible to do a batch action in P-shop if I need to convert 4500 frames from 720x486 to 720x480... I mean, because of the 1.2 PAR, would the image get any significant distortion? (doesn't really matter if it's off by a couple of pixels in this case, as far as I'm concerned)
  ecastillor said:
i wouldnt recommend a pshop action for this, because you would be modifying each image...
try a batch resizer like CoffeeCup PixConverter 2.5 or something like that
Photoshop can do batches too. Just point it to the right folder & tell it what action to do.
