Josh1587140445 Posted April 5, 2005 Share Posted April 5, 2005 Here is a project that I am currently working on. Building is modeled using VIZ 4 and rendered using VrayFree. Any comments would be helpful. Or if someone has a dark gray shingle that does not tile as bad as the one that I have. Thanks in advance. Link to comment Share on other sites More sharing options...
Tim Nelson Posted April 5, 2005 Share Posted April 5, 2005 Josh, it looks great! Except for the roof of course. I think you should try playing around with a 'tiles' map for your roof and see what you can come up with. I think you should be able to pretty accurately imitate an asphalt shingle material using that, and easily get rid of the tiling problem. Other than that, I think you could improve the glass a little by giving it something to reflect other than a solid background. And maybe not so much color in the glass. Good work though - it looks really detailed. Link to comment Share on other sites More sharing options...
Chad Warner Posted April 5, 2005 Share Posted April 5, 2005 One thing that I have used for shingles is a blend material, using a black and white image of the "lines" of the shingles for the mask between the two blend materials. Then for the "shingle" material, just use a cellular map with the color of the granules in the shingle, In this case, grey, and use a darkish grey/black color for the second material, where the "shadows" would be. Link to comment Share on other sites More sharing options...
Josh1587140445 Posted April 5, 2005 Author Share Posted April 5, 2005 Chad, That sounds like a good idea. Do you happen to an example of that or a screen shot of the settings? Link to comment Share on other sites More sharing options...
Chad Warner Posted April 5, 2005 Share Posted April 5, 2005 Sure...here you go. Hope it makes sense Link to comment Share on other sites More sharing options...
vizwhiz Posted April 5, 2005 Share Posted April 5, 2005 here is a Link to a List of Links http://www.viz2000.com/html/alfa/roof.html Roof, Roofing Materals: They must have changed their links recently here is a more up-to-date link for Certainteed http://www.certainteed.com/CertainTeed/Pro/Design+Professional/Roofing/Prodindex/Shingles/AsphaltShingles/RPGAsphaltShignlesSplash.htm here is a link to some Colonial Slate http://www.certainteed.com/NR/rdonlyres/19158D55-64FC-4805-847B-EDD5E9C20443/0/colonialstate.jpg you might have to do some FotoChopping ** hope This helps Randy Link to comment Share on other sites More sharing options...
Josh1587140445 Posted April 5, 2005 Author Share Posted April 5, 2005 http://www.certainteed.com/CertainTeed/Pro/Design+Professional/Roofing/Prodindex/Shingles/AsphaltShingles/RPGAsphaltShignlesSplash.htm here is a link to some Colonial Slate http://www.certainteed.com/NR/rdonlyres/19158D55-64FC-4805-847B-EDD5E9C20443/0/colonialstate.jpg you might have to do some FotoChopping That is where I got my roof texture. I did do a little work in Photoshop, but not enough to even the color out obviously. Link to comment Share on other sites More sharing options...
Josh1587140445 Posted April 7, 2005 Author Share Posted April 7, 2005 Here is update on the Living Units. I still need to add some people and tree on the left is a little thicker than I anticipated. So any suggestions that you may have in composition or image quality would be appreciated. Link to comment Share on other sites More sharing options...
