rcase Posted April 8, 2005 Share Posted April 8, 2005 Hello, I am having a hard time mapping a road texture to a curved road object. I lofted a road section on an arc shape and would like to map the road texture to it lining up the road stripe in the texture to the middle of the lofted object. How is this done? Mapping a linear texture to a curved surface has me stumped, please help. Thanks. Rusty Link to comment Share on other sites More sharing options...
Chad Warner Posted April 8, 2005 Share Posted April 8, 2005 When you create the lofted object, there is an option for "uvw mapping" , where you can tell it how many times to tile along the length and width. So you want to set up your material like you normally would, apply it to the loft, and then you will probably have to rotate the map in the material editor to make it line up with direction you want it go. It takes a lot of messing around, but you can get it to work. Check out Ted Boardman's tutorials on this site, he goes over lofting quite a bit. -Chad Link to comment Share on other sites More sharing options...
rcase Posted April 8, 2005 Author Share Posted April 8, 2005 Thanks. I got it to work by adding Unwrap UVW modifier. That's the only way I could get it to work. Theres a sample pic below. Link to comment Share on other sites More sharing options...
bokkins Posted April 9, 2005 Share Posted April 9, 2005 just a suggestion. staight line instead of broken lines for the curve, b'coz it means "no changing lanes on a curve". Link to comment Share on other sites More sharing options...
vertexART Posted April 10, 2005 Share Posted April 10, 2005 http://www.cgarchitect.com/resources/tutorials/smoke3d/tutorial11.asp Link to comment Share on other sites More sharing options...
