Creating Tile Patterns in PS?
Easiest thing to do is to make your tile, either 1 tile or 2 tiles or 4 tiles, (depending on how much repeating you want) with grout lines. Select the tiles and the grout, and hit Ctrl+C (copy). Go to the Edit menu, and then "Define Pattern" The selection that you just copied will show up as a thumbnail, and you give it a name. Once this is done, you deselect the tiles, go to the Edit menu again, and choose "fill"... and then choose "pattern" and choose the pattern you just made, and it will fill the image with the tiles you made.
  • 2 weeks later...
