Blowing up images --- HELP!
VCRUPI
Hi everyone,
I have to repoduce a rendering for a billboard ad (about 96"x168" @ 50/75 dpi) and was wondering if anyone knew of any software that will allow me to blow-up a rendering/image without losing too much resolution.
I'm having problems rendering it so big in 3ds max, keep getting "out of memory" errors, so i've decided to render it at a lower res and see if i could blow it up without losing too much resoultion. I can swear that i read something about a software that does this very well on this site in the past.
If anyone has any knowledge of this, can u please post ASAP. Also, if anyone can tell me if 50 dpi is enough for this ad, that would be great as well.
Thanks :D
look for bigrender or bgrender on This Page
http://www.scriptspot.com/Main_Scripts.asp?BrowseType=Render&Sort=Name
or direct i Think is
http://www.scriptspot.com/download.asp?ID=2062
maybe render the sections @ 100 dpi or 150
i just used this .ms about 3 weeks ago to render
a 36" x 24" plotfile @200 dpi i too was getting a "out of memory" error
This will create 2x2 or whatever you select sections but beware
There WILL BE A 1x PIXEL BLACK LINE ON THE LOWER AND RIGHT SIDE
of EACH of the sections, so remember to "eliminate"" THIS
otherwise TOTALLY COOL extremely helpful, bailed me out of a jamb
my vote goes with s-spline
usedthis several times to go from 72 to 300 dpi in one hit
much better than the p-shop interpolations for resize imho
for me it's mainly clients wanting a image on a site signboard so for this type of work it's no hassle to take a a3 image 2480x1753 and blow it up to 3 x 2 metres
I think you should also try this app. Originally known as Shortcut S-Spline
http://www.trulyphotomagic.com/shortcut/site/content.php?page=ourproducts&section=product_serie_info&cat=3
Best Regards,
Meher
www.drapefx.com
I second that suggestion. I have S-Spline and use it on a regular basis. Very customizable (sharpening and antialiasing settings) and works as a plugin for Photoshop, if desired.
