insomniac Posted April 1, 2003 Share Posted April 1, 2003 hi guys i wondered what is the best motherboard that supports dial prossesors (AMD) and what is better... a Ge-force VGA with a 8X AGP with 64 MB DDR or a Ge-Force with 4X but with 128 MB DDR ? and what is the defrance between them ? thanx Link to comment Share on other sites More sharing options...
Raffaello.S. Posted April 1, 2003 Share Posted April 1, 2003 Hi i think that the best motherboard solution for prof. aplication is the Tyan.. but.. Just whait for Graig, hi is the expert.... Link to comment Share on other sites More sharing options...
Greg Hess Posted April 1, 2003 Share Posted April 1, 2003 1) There are only three Dual AMD boards which support 2600+ MP's. http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_869_965^7928|66379_2_0_7927_us-en,00.html Out of those three, I'd probably lean towards the MSI solution. Alot of Dual AMD boards have stopped being revisied, and even produced. For this reason unless your on a budget, you might want to consider other solutions as well. 2) 8X AGP is more of a FAD then a giver of performance. I wouldn't base a decision on whether a card had or didn't have 8X AGP. Of which card is faster... The 64 Meg Geforce4 Ti 4200's "usually" have higher clocked and faster ram, then the 128 meg Ti 4200's. All depends on what resolution you run, whether which one will be faster. Would help if you pointed out actual card designations. Link to comment Share on other sites More sharing options...
