aflack Posted April 22, 2005 Share Posted April 22, 2005 In the current image I am doing there is a huge 10 meter high yellow plastic box that is lit from with-in. Is there a way I can make it glow? I am using vray to do the render. Thanks for your help. Link to comment Share on other sites More sharing options...
jucaro Posted April 22, 2005 Share Posted April 22, 2005 Vray already has a self illuminating material (VRayLightMtl). Or you can do it via Object ID and Lens Effects in the Environment and Effects rollout. F1 also helps. Link to comment Share on other sites More sharing options...
jvlive Posted April 23, 2005 Share Posted April 23, 2005 or you could use a standard material, place an output map in the diffuse slot, then up the rgb amount. maybe 1.5-3. just tried it yesterday. hehe. Link to comment Share on other sites More sharing options...
