RyanSW Posted April 23, 2005 Share Posted April 23, 2005 Now I know Lightwave is 3D Software not CAD. So how does one do architecture in Lightwave? Should I do my floorplans in AutoCAD or Rhino and then import them to Lightwave to kinda extrude? Or how does it work? Also how does scale work in Lightwave? Are there any basic tutorials to build like a shed or something - no textures or anything. Just the modelling aspect of it. Link to comment Share on other sites More sharing options...
IC Posted April 23, 2005 Share Posted April 23, 2005 I've been using AutoCAD and LW for years. They both have their problems but they are great programs. What I generally do for exteriors is: Model in AutoCAD(or whatever) and export to 3ds. Take the 3ds file into LW and texture, embellish and render. Sometimes I model in LW too but if you're working from a dwg file, it's an opportunity lost not to model in AutoCAD. For interiors: Model, texture and render in LW. You won't get better tutorials for all kinds of CG work than Dan Ablan's Inside LightWave books. LightWave isn't CAD but then neither are any of the other 3D apps. I have it set to work in mm as we work in metric in the UK. The scale in LW is very intuitive. When you're modelling from a 2D drawing, you just switch to numeric mode and you can type in (eg) 3.256mm+2.122mm+0.980m+1.345mm and it does the calculation for you. Link to comment Share on other sites More sharing options...
RyanSW Posted April 23, 2005 Author Share Posted April 23, 2005 so I should model in Cad or ArchDesktop and then just open LightWave 7 and never even touch Modeler until Im working on an interior space? Link to comment Share on other sites More sharing options...
IC Posted April 23, 2005 Share Posted April 23, 2005 It's not quite that simple. Modeler goes hand in hand with Layout if you want a good render. Open the exported model in Modeler first then, press m for merge. Check the scale in the bottom left hand box. Then attend to scale and texturing. After that, spend as little or as much time as you have on the model. You've got to get it to Layout asap and once rendering has started you can still refine the model (with FPrime you can refine as you go with just about no delay). Link to comment Share on other sites More sharing options...
otacon Posted April 24, 2005 Share Posted April 24, 2005 I would model with whatever program your most comfortable with. For me i do everything in lightwave, model, texture, render...but then again im not very familiar with autocad. Plus i think its most efficient if you can keep the number of programs you have to use to a minimum. Link to comment Share on other sites More sharing options...
RyanSW Posted April 24, 2005 Author Share Posted April 24, 2005 I would model with whatever program your most comfortable with. For me i do everything in lightwave, model, texture, render...but then again im not very familiar with autocad. Plus i think its most efficient if you can keep the number of programs you have to use to a minimum. Can you do floorplans though in LW? Link to comment Share on other sites More sharing options...
otacon Posted April 24, 2005 Share Posted April 24, 2005 No, I usually convert the dwg to dxf and work from that to make floorplates. Example here Link to comment Share on other sites More sharing options...
Allen Posted April 25, 2005 Share Posted April 25, 2005 Sounds like I work the same way as Otacon: DXF for the base vertexes (what's the plural for vertex?), and model from there. Oh, and I supposed you could do floorplans from LW - but it would be like digging a ditch with a hammer - the hammers a great tool - but it's not for digging ditches. Get a CAD program. (http://www.intellicadms.com) Link to comment Share on other sites More sharing options...
vpii@vpii.com Posted April 29, 2005 Share Posted April 29, 2005 What is otacon working for Charles now at 2dimes? Link to comment Share on other sites More sharing options...
Allen Posted April 29, 2005 Share Posted April 29, 2005 What is otacon working for Charles now at 2dimes? He could probably tell you...but then he'd have to kill you. Talented team there. Link to comment Share on other sites More sharing options...
MooseDog Posted May 18, 2005 Share Posted May 18, 2005 http://www.wtools3d.com/ if your budget supports it, this is a pretty nifty lw tool. stays consistent with otacon's less moving parts philosophy, which i second . for me at least, modeling in lw is painlessly fast and easy. to each their own tho Link to comment Share on other sites More sharing options...
Charles Gaushell Posted May 18, 2005 Share Posted May 18, 2005 LOL... Thanks Allen - Kudos to everyone in this thread. Yes, Jason has been with us for almost a year now. Some day I'll get the rest of you here. We would have a lot of fun and hopefully a lot of money.... Link to comment Share on other sites More sharing options...
Allen Posted May 19, 2005 Share Posted May 19, 2005 Yea...live in a loft over looking the river...I could do that. Back to work (placing nose back on grindstone) Link to comment Share on other sites More sharing options...
Jure Posted May 26, 2005 Share Posted May 26, 2005 I work the same way as other have allready mentioned. First I clean up floorplans in Autocad to get rid of unnecessary layers and lines then flatten the whole thing to one layer. I save that as v12 dxf and open it in modeler. From there it's straight modeling with LWcad (very helpfull!!!) and other standard tools (extrude, bevel, band saw, bridge etc.). Link to comment Share on other sites More sharing options...
ihabkal Posted May 26, 2005 Share Posted May 26, 2005 LOL... a lot of money.... that's what my previous employer told me... Link to comment Share on other sites More sharing options...
shortstuf2890 Posted June 8, 2005 Share Posted June 8, 2005 How do you save an object in lightwave as an image file so you can view it in other programs. Link to comment Share on other sites More sharing options...
IC Posted June 8, 2005 Share Posted June 8, 2005 What do you mean exactly? You can screen grab by pressing the 'print screen' button or you can render an image of your object (try the help files for that one-the options are huge). Link to comment Share on other sites More sharing options...
MetaHumanitY Posted July 6, 2005 Share Posted July 6, 2005 No, I usually convert the dwg to dxf and work from that to make floorplates. Example here That´s a fantastic model and render! Radiosity? Link to comment Share on other sites More sharing options...
otacon Posted July 7, 2005 Share Posted July 7, 2005 Background radiosity. Link to comment Share on other sites More sharing options...
4DM Posted July 7, 2005 Share Posted July 7, 2005 (what's the plural for vertex?) I believe the word you are looking for is 'vertices'... Cheers, D. Link to comment Share on other sites More sharing options...
Allen Posted July 10, 2005 Share Posted July 10, 2005 Duh...I knew that :-) Thanks. Link to comment Share on other sites More sharing options...
bjornkn Posted August 2, 2005 Share Posted August 2, 2005 My number 1 choice for modelling architecture to be used in LW (or elsewhere) is SketchUp. It works very well with Autocad drawings, and it exports uv-mapped objects as 3ds, obj and others. It's a great program, very user-friendly and along with a nice set of user-defines shortcuts it gives you a great workflow Link to comment Share on other sites More sharing options...
3dworks Posted August 2, 2005 Share Posted August 2, 2005 very happy using formz here, which has a good LW im- and export. in my opinion this program has one of the best combinations of CAD features and solid modelling features: layers, symbols, instancing/cloning, both real solids and surfaces, very good boolean operations, updated ACIS core. it is also useful if you do work with different renderers - we use it for both EIAS and LW. in our workflow FZ is for the geometry creation process only. surfacing and texturing is then all done in modeler/layout. cheers markus Link to comment Share on other sites More sharing options...
Limbus Posted August 4, 2005 Share Posted August 4, 2005 The very nice LWCAD Plugin was allready mentioned. I find these to free snapping plugins irreplaceable when doing Archviz stuff: SP_Move http://www.flay.com/GetDetail.cfm?ID=2180 and Snap_Line http://www.flay.com/GetDetail.cfm?ID=1998 Florian Link to comment Share on other sites More sharing options...
sonny Posted November 11, 2005 Share Posted November 11, 2005 try plotting yor dwg as eps from autcad then import them into lw as eps. rescale the impoted eps to the right size in modeller then proceed modelling either by tracing over the imported plan from another layer or by using lwcad for measurement precision. Link to comment Share on other sites More sharing options...
