RODRI Posted April 23, 2005 Share Posted April 23, 2005 hi! i have some troubles whith radiosity, i think that i need some help to use it.exposure control, etc it`s ok. Link to comment Share on other sites More sharing options...
DennisHolland Posted April 24, 2005 Share Posted April 24, 2005 It lacks the nice shadows radiosity normally produces here. Have you crancked up the brightness a lot in the logarythmic exposure control while previewing the render? Maybe do a re-calculate for the radiosity because this could be way better whe you try some different settings. Just play around... Link to comment Share on other sites More sharing options...
RODRI Posted April 24, 2005 Author Share Posted April 24, 2005 dennis: thank you for your tips. i´ll try with brightness in logarythmic exposure control. best regards: rodrigo garcía. Link to comment Share on other sites More sharing options...
DennisHolland Posted April 24, 2005 Share Posted April 24, 2005 Did you use a lot of brightness control in this test? If yes lower it to default appr. 60, leave all lights out inside and do a calculation with only the sun shining in (cranck up the multiplier to 2 for the sun, use a target direct). Good luck, Dennis Link to comment Share on other sites More sharing options...
Hao La Posted April 24, 2005 Share Posted April 24, 2005 I think u should use final gather for radiosity Link to comment Share on other sites More sharing options...
RODRI Posted April 25, 2005 Author Share Posted April 25, 2005 Dennis: THANK YOU, again for your value tips. i´ll try your advise. best regards: Rodrigo García. Link to comment Share on other sites More sharing options...
RODRI Posted April 25, 2005 Author Share Posted April 25, 2005 Hao la: what is final gather, rendering window?. thanks a lot for your advise. best regards: rodrigo garcía. Link to comment Share on other sites More sharing options...
Hao La Posted April 26, 2005 Share Posted April 26, 2005 Oh sorry my bad , I mean the Regather Direct Illumination. Setting the Rays per Sample to 25 and the Filter Radius to 15 . It may be fixed ... Link to comment Share on other sites More sharing options...
RODRI Posted April 26, 2005 Author Share Posted April 26, 2005 Hao La: i ´ve been trying with your advises but my radiosity is too bad. i use ies sun and ies sky only. i use logharithmic control but i couldn´t have a nice render. thank you for your advises. best regards: rodrigo garcía. Link to comment Share on other sites More sharing options...
