only3d Posted April 24, 2005 Share Posted April 24, 2005 hello evrybody im using a path to lead an object i want to film moving, but- for some reason when the object reaches the end of the path (its a linear path not a circular) it goes to the starting point and begins again (although i dont want it 2) so how do i make it stop in the end of the path and continue my walkhru with the object in place. Tnx in advance (im using viz 4) Link to comment Share on other sites More sharing options...
Jennifer Posted April 25, 2005 Share Posted April 25, 2005 You need to go to the Motion Tab, and with the object selected and AutoKey On, at frame 0 and the end frame edit the percent value to 0 and 100, respectively. Occasionally the numbers get skewed, and you get that looping problem. Have fun! Link to comment Share on other sites More sharing options...
only3d Posted April 25, 2005 Author Share Posted April 25, 2005 Hi jennifer first of all tnx 4 your quick reply sec'- although my problem was a little different than what i thought u made me notice it! well i guess i forgot 2 mention that my "object" was actually a string of objects (kinda like a train) and i found out that if i clone them backword instead of forward then its ok tnx anyways! till next time.. Link to comment Share on other sites More sharing options...
