pheeken@streamyx.com Posted April 24, 2005 Share Posted April 24, 2005 hi all....this is my 1st render with brazil and touch up with photoshop pls give some comment...thanks Link to comment Share on other sites More sharing options...
DennisHolland Posted April 24, 2005 Share Posted April 24, 2005 What version? I think you need to check skylight in the luma server. For outside scenes it may be better to let the indirect illumination un-checked in the luma server rollout. Better add a target direct (covering whole scene) for sun simulation, check brazilshadows on. Just let all settings default and do a testrender (shift Q) then you see what you've got to tweak. Dennis Link to comment Share on other sites More sharing options...
pheeken@streamyx.com Posted April 25, 2005 Author Share Posted April 25, 2005 thanks for to comment ,this is an update on the setting that you teach...by the way my brazil version is 1.2.53 Link to comment Share on other sites More sharing options...
DennisHolland Posted April 26, 2005 Share Posted April 26, 2005 That is much better. Try to have your cam focused on eyelevel (6 ft or 1.80 meters looking straight forward). Where are the shadows of the little brown pools and trees. Are they 2D mappings? If the trees are rpc's (which is very doubtfull), Brazil and rpc having some troubles now and then. Maybe lower the rgb values of the grass and for the bushes. Big step forward, regards. Dennis Link to comment Share on other sites More sharing options...
pheeken@streamyx.com Posted April 27, 2005 Author Share Posted April 27, 2005 That is much better. Try to have your cam focused on eyelevel (6 ft or 1.80 meters looking straight forward). Where are the shadows of the little brown pools and trees. Are they 2D mappings? If the trees are rpc's (which is very doubtfull), Brazil and rpc having some troubles now and then. Maybe lower the rgb values of the grass and for the bushes. Big step forward, regards. Dennis thanks dennis the pools and trees are not rpc , i use photoshop to apply them in the image . now the client want to make some changes on the image , i finish them then i'll show you the final one. Link to comment Share on other sites More sharing options...
