raterry Posted April 26, 2005 Share Posted April 26, 2005 Hi there, I'm having a problem importing a CAD file into MAX 5.1. The CAD file is a topographical file that is a whole bunch of lines with indicators of how high (in feet) that section of land is. I'm just trying to import all those lines into Max so I can extrude and have some semblance of the land mass I need. I've tried saving as .dxf, .dwg. but MAX imports either nothing or just one line. I really am not too familiar with CAD so I figure I'm doing something wrong there. Any ideas would be greatly appreciated. -=rob I've attached a jpeg example of what I'm trying to import. it's a screen cap of the CAD file. Link to comment Share on other sites More sharing options...
karl zacharias Posted April 26, 2005 Share Posted April 26, 2005 Do This Process All The Time...first Of All The Lines From Cad Should Be P-lines, And They Should Be Closed In Order To Extrude Them In Max. Try Limiting The Number Of Increments Because You May Have To Retrace With P-lines In Cad Or Even Retrace In Max Using Lines. The Text Will Not Import. If The Lines Do Import, You'll Need To Go To The Sub-object Level And Detach The Segments As Clones So You Can Vary The Elevations (because It Appears That Your Cad Lines Are On One Layer). Link to comment Share on other sites More sharing options...
raterry Posted April 26, 2005 Author Share Posted April 26, 2005 Thanks for the reply, my plan was to re-draw all the lines in Max because I know they are all open in the cad file, it's actually just a small portion of a larger land mass so all lines are just cut off at the ends. It just seems like they are not there at all when I import, is it because they are not P-lines in CAD, if so can you tell me how to make them P-lines in CAD? thanks again, -=Rob Link to comment Share on other sites More sharing options...
rcase Posted April 26, 2005 Share Posted April 26, 2005 If they are splines, you can search the web for a LISP command to turn your SPLINEs to PLINEs. If you can't find one, you'll have to redraw them in AutoCAD as closed p-lines. You can't turn a spline into a pline. Hope this helps. Link to comment Share on other sites More sharing options...
