constraining targets in X-Z plane
edub
I want to use image mapped planes of people that always face to camera. If I apply a target tag to the plane and make the camera the target object the plane tilts out of the X-Z plane.
How can I constrain the plane to the X-Z plane, so it only rotates in the Y-axis.
Hope I explained that well enough. Thanks.
-Erik
I've done this before... what you need to do is create a dummy object centered on the plane. Then link the plane to the dummy object. Have the plane only inherit the x and z rotation of the dummy. Assign the lookat controller to the dummy to follow the camera and you're done.
It's been a while, but I think that will do it.
-Dave
Got3d.com
well, I solved my own problem - and it was really easy (once I dug through the manual!!)
I used the "Look at camera" tag (duh).. not the target tag. Deselecting the "change pitch rotation" option constrains the X-Z plane
Next obvious question--how to have the plane only get x and z rotation control from its Null?
Try this thread for a discussion about this subject and a Look at Sun expression I created to point an invisible image plane toward the sun (to cast the shadow) while the "Look at Camera" tag points the visible image toward the camera.
I hope you find this useful.
