Vray Bleeds Again
doujay888
Here are two images showing a Vray rendering with photon map
and direct computation. However i'm still facing the same problem
if you watch the images closely. The direct comp render has an
orange shades output and same as to with the photon map only
thing is it's blotchy. I have attached as well the settings.
Any suggestions on this? PLease. Im submitting this by tommorow.
HELP!
hello, I'm new in vray also, and I encounterd the same problem, what I did is I lowered the value of secondary bounce and actually all bounces and didn't use photons settings anymore. In that way, I was able to lessen the bleeding. red is a very strong color, it will really bleed. hope I was able to help you.
hi
there is a simple trick that you could try..
if you calculate irradiance map or light mapping (if you don't have glossy refelections traced with light map) with an override material made of a standard 200white colour material, you don't have any bleed at all
after this you disable the override material option and render again with the irradiance and light mapping loaded from files ( that don't have bleed at all)
you will have a perfect look
another option is creating another set of materials with desaturated textures and calculate imap+lightmaps and going back to render with the original set of texture
note:: in lightscape we had a simple parameter to reduce the bleed efect
to reduce or increase the bleeding of any object:
In the RENDERER window, go to VRAY SYSTEM tab, OBJECT SETTINGS, and increase/decrease the amount of GI of that particular object.
