ecastillor Posted May 1, 2005 Share Posted May 1, 2005 Almost all of my bitmap based materials look overexposed when i use radiosity solution....how do i control this? ill post an example later...Thank you Link to comment Share on other sites More sharing options...
tstephens Posted May 1, 2005 Share Posted May 1, 2005 Could you list the Radiosity settings you are currenty using (Initial Quality, Iterations, Filtering) and the Logarithmic Exposure Control Settings you are using (contrast, brightness). It will be easier to help if I know what your present settings are. Tod Stephens Link to comment Share on other sites More sharing options...
Buffalo Bills Posted May 2, 2005 Share Posted May 2, 2005 ecastillor, Without seeing an image, it sounds like what you need to do is go into each material that looks over exposed and make sure that the reflective value is not more than what really is recommended for it. You can adjust your materials by clicking on the map in the diffuse box and go all the way down to the bottom of the parameters and find the output parameter check the color enable map box and slide the right little square down to adjust the brightness of your materials. Or it could be your lighting settings like Tod Stephens mentioned. Link to comment Share on other sites More sharing options...
ecastillor Posted May 2, 2005 Author Share Posted May 2, 2005 80% Quality refine iterations 3 filtering 2 65 brightness 65 contrast the pictures look washed out Link to comment Share on other sites More sharing options...
Buffalo Bills Posted May 2, 2005 Share Posted May 2, 2005 ecastillor, For interiors I try to set my brightness to 50% and contrast to 55%. If that doesn't work then you just need to go into your materials parameters and turn down the rgb output of the materials. I left you a message before this one explaining just that. I would also go 85% for quality refine iterations to 10. for better quality. Not bad so far! Link to comment Share on other sites More sharing options...
Brolloks Posted May 5, 2005 Share Posted May 5, 2005 Hi Have you checked whether you have exposure control on or off? Link to comment Share on other sites More sharing options...
