salf Posted May 2, 2005 Share Posted May 2, 2005 I got a issue with my dimension styles, whenerv i used them on a drawing, if i try to move the drawing (relocate it on the MODEL SPACE), it stretches all the dimension tabs, I used to move the drawing with the dimensions in it with out problem, but now i cant. DUnno if you understand me. Link to comment Share on other sites More sharing options...
Audrie Posted May 3, 2005 Share Posted May 3, 2005 That is because you have associative dimensions on as a default. If you don't want them on try using... Tools /Options./User Preferences tab/. Under Associative Dimensioning, select or clear Make New Dimensions Associative. To assist in moving objects with associated dimensions while leavign the dimensions in tact - the command you want is dimdisassociate This will allow you to unlink the dimensions before you move what they are attached to. Hope this helps Regards Audrie Link to comment Share on other sites More sharing options...
salf Posted May 4, 2005 Author Share Posted May 4, 2005 Just saw your reply, thanks, gonna try it tomorrow at the office. Link to comment Share on other sites More sharing options...
