hosamzidan Posted May 4, 2005 Share Posted May 4, 2005 hi there i just have this problem with Xrefs .... that i can't bind an Xref object To the drawing that it's attatched to & i don't know what is the main problem in this thanks for your pricious time -Hosam Zidan Link to comment Share on other sites More sharing options...
Tim Nelson Posted May 4, 2005 Share Posted May 4, 2005 What is the error that you get in the command line when you try to bind it? Link to comment Share on other sites More sharing options...
hosamzidan Posted May 4, 2005 Author Share Posted May 4, 2005 a dialog box appears .... i attatched it below Link to comment Share on other sites More sharing options...
Tim Nelson Posted May 5, 2005 Share Posted May 5, 2005 Hmm, I don't think I've seen that one before. I would try to run the 'recover' command on the file you are trying to bind, and also purge it a few times until everything is clear. Also make sure there are no other attached xrefs to the xref you are trying to bind. If that doesn't work, I would then w-block your entire xref file into a clean new file and then try it. Link to comment Share on other sites More sharing options...
hosamzidan Posted May 5, 2005 Author Share Posted May 5, 2005 Well Thanx Tim but the problem was solved after rebooting the machine Link to comment Share on other sites More sharing options...
Tim Nelson Posted May 5, 2005 Share Posted May 5, 2005 Ahh, even better! Link to comment Share on other sites More sharing options...
