Rack Mount Render Farm
In the Canadian market ($$), this isn't a very easy decision to make. I've found that most rackmount suppliers are US based, and cary US costs with them (BOXX, for instance). I looked into rackmount solutions over a year ago but decided that the value wasn't there for the quantity that we were purchasing. We went with stripped-down Dell PWS 470's, mounted in relay racks. They come in at 4U when mounted with a rack kit, and cost us
I guess your key questions are going to be:
1. How many machines will be purchased?
2. How much space is available?
3. How much $$ can you spend?
Hope this helps -
We use Boxx and I've had no problems at all. I wouldn’t say that they are the cheapest thing on the market but for the price you get a machine that has been tested with the 3d app you are using plus great tech support. Were on a 2 year cycle with these machines and I fully expect to continue purchasing boxx both for may rack mounted units and my work stations.
I assembled a couple 2U in 2002 from components from newegg.com, costed me $1200 each, dual athlon MP 2800+
didn't use them as my day job prevented me from getting freelance work. but I tested and learned a lot. running a mini farm at home taught me stuff I am using at my new job.
hi jeff and no i have not forgotten rtre
avoid 1 u racks as they tend to be that little more $$
run very hot and due to the fans are very noisy
2 u cases are cheaper and quieter
i sourced 4 units last year and after starting with boxx went with a local i.t. server tech who built boxes for around half the $ but same spec at the time
