maurocan Posted May 5, 2005 Share Posted May 5, 2005 here are 2 images. i´ve prepared the first one for 3dmax5 with vray, and now i´m trying to step into 3dmax6.... but OH! same image appears like this (second image). does anyone know whats going on???????? everything turns gray and dull... thanks Link to comment Share on other sites More sharing options...
ihabkal Posted May 5, 2005 Share Posted May 5, 2005 could be one of many things, but first check environment, turn off exposure control. tell me today I wanna know... Link to comment Share on other sites More sharing options...
maurocan Posted May 5, 2005 Author Share Posted May 5, 2005 exposure control is turned off......................... Link to comment Share on other sites More sharing options...
ihabkal Posted May 5, 2005 Share Posted May 5, 2005 Got it. I'll see if I can find anything...thanks, Ihab Link to comment Share on other sites More sharing options...
ihabkal Posted May 5, 2005 Share Posted May 5, 2005 Had the same awful results with max 7.5 then I tweaked for about 30 minutes and I got this attached. the file is max 7.5 I don't think you can open it in max 6, but do this: lower dimmer on all photometric lights to 100 instead of 450 this is important. in Vray: G-byffer/color mapping change to Linear Multiply. THis is the same feature I told you about that mad it dull. max has it name as exposure control. I assure you this is mainly the problem. change dark multiplier from 3.1 to 1.7 only. too much would cause dullness. I never go over 2 usually. change GI primary bounces to 1 instead of 1.1 change secondary bounces to .5 only. you'll get the image below... then tweak the lights to your taste... I saw your website while it was rendering cooool interiors. I love not 1, but 4-5 at least. nice work. You need help? I need help....You are great with interior renderings and lighting... I think that's it....If you need the max 7.5 file tell me... thanks, Ihab Link to comment Share on other sites More sharing options...
maurocan Posted May 6, 2005 Author Share Posted May 6, 2005 Hey, thanks for your time and patience !!!! you've totaly made it, (see the attached file)... i`ll work images on max 6 from now on... i´m glad you liked my page... if you see the way we could do things together well you have my email. thanks again for your help and time... hope i can improve a lot more... http://www.3dmgroup.com.ar Link to comment Share on other sites More sharing options...
ihabkal Posted May 6, 2005 Share Posted May 6, 2005 you're welcome... thanks, Ihab Link to comment Share on other sites More sharing options...
