Ian P Posted June 1, 2005 Share Posted June 1, 2005 Hello Everyone, This is my first post on this site, I plan to use this forum for desprately needed help. any comments welcome for this wip. Link to comment Share on other sites More sharing options...
lambros Posted June 1, 2005 Share Posted June 1, 2005 Hi there, your modelling is good, but the image looks a bit flat. What software are you using? Did you apply any GI? Texturing is ok, but it would surely look much better with proper lighting. Link to comment Share on other sites More sharing options...
Ian P Posted June 1, 2005 Author Share Posted June 1, 2005 I agree it looks very flat, Using max 5, forgive my ignorance but not sure what GI is?,will it help give some depth? Thanks for replying Link to comment Share on other sites More sharing options...
lambros Posted June 1, 2005 Share Posted June 1, 2005 GI stands for Global Illumination. Max has two built-in GI solutions: one is lightracer (use a skylight, and add Lightracer to the Advanced Lightning Rollout in Render settings) and the other is radiosity. Radiosity can be used with any kind of lights, requires a pre-calculation which takes some time, and renders the effect of light bouncing on and off surfaces. Later editions of max have mental ray integrated, which can be used for Global Illumination, but requires lots of experimentation and practice to get decent results. Try max's help, or do the tutorials, they will clarify things! Link to comment Share on other sites More sharing options...
Ian P Posted June 1, 2005 Author Share Posted June 1, 2005 Ahh, Yes sorry I tried that first off (Didn't get the abbreiviation, Its been a long day), am trying spots in a dome array at the moment as this will be an animation and I can't have big render times.any tips on similar lighting without huge render times?? Link to comment Share on other sites More sharing options...
ecastillor Posted June 1, 2005 Share Posted June 1, 2005 If you use radiosity, once the calculation is donde, the frames are actually pretty fast....i would say faster than fakiosity...(light dome) Link to comment Share on other sites More sharing options...
