Sketchrender Posted June 8, 2005 Share Posted June 8, 2005 Hi again Question One I have a model, and All the window breakups are 2D lines from autocad, how do I render the 2d lines so they come out as rendered lines in my window lines.They are on there own layer, and buildings are file referenced in. Second question I have messed up my rpc's where should the images be kept, and were should main plug in be kept? thanks phil Link to comment Share on other sites More sharing options...
J.R. Posted June 8, 2005 Share Posted June 8, 2005 1. Method: Select Spline - Modification-panel - Rendering - Mark "Enable in Renderer" 2. Method: Select Spline - Apply Modifier "Renderable Spline" (Useful for a larger number of Splines 3. Method: Actually model the Splines as Geometry with the Loft Command and a custom profile Link to comment Share on other sites More sharing options...
ecastillor Posted June 8, 2005 Share Posted June 8, 2005 Perhaps Q1 needs some clarity Phil? Rendering lines in Max is easy ~ just use what's in the modifier panel. ...But "rendered lines in my window lines"? ...Me no comprende! Bunny makes me laugh!!!!! WTF!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Victor Erthal Posted June 8, 2005 Share Posted June 8, 2005 Yes, Jan-Ruben Fischer is right. But i don't think its a very good idea to use loft in this case. You can simply mark the renderable box in the modify pannel on your spline and nottice that there is a checkbox close to it named "display render mesh". well, click on it. After that just convert it to poly and you have actual geometry without having to loft anything. Link to comment Share on other sites More sharing options...
ihabkal Posted June 8, 2005 Share Posted June 8, 2005 Bunny makes me laugh!!!!! WTF!!!!!!!!!!!!!! just had pancakes myself. Link to comment Share on other sites More sharing options...
Sketchrender Posted June 9, 2005 Author Share Posted June 9, 2005 Thank you very much, after alot of trial and error, i got it last night. thank you anyway, pancakes and all. there is very little you can't do in max. phil Link to comment Share on other sites More sharing options...
