Tim Saunders Posted August 28, 2005 Share Posted August 28, 2005 ok the building is only about 1/4 modeled, but i wanted to take a uick time out on modeling it and work on something i've never tried before; glass block. i plan on posting wips on this spare time practice project throughout the proccess, but i wanted to get some feedback on my attempt on the glass block. like i said, i've never done this before so be gentle. i looked around for a bit and couln't find any texture maps i was satisfied with so i made my own and mixed in some color. any suggestions for improvement? keep in mind, i have no lights set up or any environment map. Link to comment Share on other sites More sharing options...
caddiellac Posted August 28, 2005 Share Posted August 28, 2005 rmaytee said: i looked around for a bit and couln't find any texture maps i was satisfied with so i made my own and mixed in some color. Hi Tim, I think modelling wise it's working.. can I know how or what software you used to make your own texture map? Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 29, 2005 Author Share Posted August 29, 2005 i used photoshop. i just drew 3 lines horizontally and vertically evenly spaced apart, then with the brush with soft edges and like 40% opacity, i put a blurred dot in the middle of each square as shown in the second image. i used the map as my difused color map and mixed in a bit of green color, and decreased the opacity of the material. and i used the same map as the bump map cranked up to like 150 or so. i used reflect refract in bot the reflection and refraction map slots and played with the levels a little. i'm open to any ideas for improvement. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 29, 2005 Author Share Posted August 29, 2005 i was afraid i would have this problem. i guess vray (free) does not accept reflect/refract materials. i guess i'l have to figure out another way to do that glass block. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 29, 2005 Author Share Posted August 29, 2005 and no, i'm not leaving my road and sidewalk like that. Link to comment Share on other sites More sharing options...
Dynedain Posted August 29, 2005 Share Posted August 29, 2005 rmaytee said: and no, i'm not leaving my road and sidewalk like that. Use standard materials with the vray map in the reflect/refract slots to setup your reflection and refraction Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 29, 2005 Author Share Posted August 29, 2005 thanks anthony. i'll give that a try when i get home from work tonight. i never knew what the vray map was used for. hope it works. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 31, 2005 Author Share Posted August 31, 2005 ok i think i'm pretty much finished with this one. any suggestions before i render a high rez version? Link to comment Share on other sites More sharing options...
Tommy L Posted August 31, 2005 Share Posted August 31, 2005 Looks a bit dark and gloomy. Whats the image for? Link to comment Share on other sites More sharing options...
salf Posted August 31, 2005 Share Posted August 31, 2005 GOOD WORK, thanks for sharing, final render looks great, but too dark. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 31, 2005 Author Share Posted August 31, 2005 i agree with you. i am going for a more overcast feeling, hence the lack of harsh shadows, but it is for sure a bit too dark. it is just for fun. just a project for practice i am doing at home at night. Link to comment Share on other sites More sharing options...
Tim Saunders Posted September 2, 2005 Author Share Posted September 2, 2005 here's the final product. not much change. a little stronger light, and some minor ps touch up. Link to comment Share on other sites More sharing options...
