Aaron2004 Posted November 28, 2005 Share Posted November 28, 2005 Hey all, I'm working with Mental ray for the first time after working with VRAY for a while. I know I'm probably missing one check box that is screwing up this render...what is it? I have final gathering on. I'm not using any mental ray materials...but would that make that great of a difference? Thanks! Aaron Link to comment Share on other sites More sharing options...
mohamedberry Posted November 29, 2005 Share Posted November 29, 2005 check your exposure control settings... and use a skylight to add more light to the shaded areas (need FG to be enabled). i think MRay works much better for interiors though, try it out and post your updates Link to comment Share on other sites More sharing options...
Aaron2004 Posted November 29, 2005 Author Share Posted November 29, 2005 That was the problem...I needed a skylight. The other problem was the fact that my directional light had MR shadows...which I thought would help, but those are what created the jaggies. I changed it to Ray traced shadows and it came out fine. I usually do use VRAY free for exterior things, but I'm needing to do some baking, and VRAY free doesn't allow for that. I might just revert back to a scan line render with a skylight for baking...I'll have to see which one is faster. Thanks! Aaron PS. are there any good tuts out there for interior Mental Ray animations in Max/Viz? Link to comment Share on other sites More sharing options...
enigma Posted November 29, 2005 Share Posted November 29, 2005 Mr shadows workd like an area shadow in MR you would have to set the accurate dimensions of the light source in the area light params. based on the scale of your scene. What i usually do is to set the size of the area light parameter under the light parameters to around 1-5% of the size of my structure. maybe that caused the jaggies. Try changing the background color in the environments dialog to pale blue. BG has great effect on FG. Also check the exposure as mohamed suggested. hope this helps.... Link to comment Share on other sites More sharing options...
