salty_dogs Posted April 19, 2006 Share Posted April 19, 2006 with an acad background... how do i draw splines with coordinate values... quickly. 1. is there an ortho type function that you can turn on/off. you know, like restrain to x and then y directions with distance you can type in. 2. other than using autogrid at object creation, is it possible to set up a drawing plane using points? i find that the polygon tools for editing surfaces is easy, but im having trouble defining the generative splines... and locating something like openings within surfaces. it seems all too freeform... 3. if you have a wall defining surface and you want to locate an opening at a particular height from the ground and a certain size... how do you all do this? Link to comment Share on other sites More sharing options...
only3d Posted April 19, 2006 Share Posted April 19, 2006 hi salty 1- use 'shift' while u draw or just try to stay within the the grid co' using 'snap 2 grid' (although i know its not allways possible) 2- sorry i dont understand the question.. 3- do u know how 2 work w AEC objects? if so its just a matter of inserting it and changing the z co' (tip- its easier if u work w a segmented wall) if u dont then try 2 pick it up using HELP or something cuz its hard 2 explain it in writing good luck Link to comment Share on other sites More sharing options...
salty_dogs Posted April 20, 2006 Author Share Posted April 20, 2006 1. yeh that's what i was looking for... the shift key. sorry im a little slow, so i start the line, hit the shift key then.... how do i make the line a particular length? like 5 units or whatever. Link to comment Share on other sites More sharing options...
