yogeshwagh Posted May 9, 2006 Share Posted May 9, 2006 hi to all, I am working on vray but i have got a problem in my animation when objects are moving. the irr map which i have saved it doesn't calculate after some frames where my objects ae moving. the problem is created for the shadows. i use to save irr map and lightcache everytime and giving path of it, it works with only when the camera moves with the objects. please help me out to do the settings for the moving objects in vra render Link to comment Share on other sites More sharing options...
pg1 Posted May 9, 2006 Share Posted May 9, 2006 Hey As I haven't done many animation with moving object I can't help that much but you can use irmaps I think you need to use qmc as both primary and secondary bounce. there is a great tutorial on the chaosgroup website. You need to register with chaosgroup get access. Then go to the support section then vray docs then vray help index there are a group of tutorials at the bottom of the page including moving object animations ggood luck Link to comment Share on other sites More sharing options...
pg1 Posted May 9, 2006 Share Posted May 9, 2006 Sorry I mispelled that You CAN NOT use irmaps for moving objects Link to comment Share on other sites More sharing options...
ApeiNe Posted May 9, 2006 Share Posted May 9, 2006 nop, no Irrmap QMC as primary is needed... U can use the lightcache as secoundary to be a bit faster than QMC only. Just take care to set Vray::rQMC Sampler like that : Noise threshold (quality) : 0,001 or 0,002 not more Adaptative subdivs : 1,0 or 0,9 not less and keep the rest as default Keep default parameters for primary bounces too and the Lightcache around that : Subidivs : 1000 or more size : 0,01 or 0,005 interp samples : 5 That work fine for me, a little grain will appear but that must be easiest to eliminate than in post prod than a flickering. Another solution with Photon map and the plugin used to render moving objects >> http://www.spot3d.com/vray/help/VRayHelp150beta/tutorials_anim.htm Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 9, 2006 Share Posted May 9, 2006 That is not 100% true. You can use irradiance map with moving objects, you just can't bake it. You also have to turn up the quality a lot, and it is very hard to get a good result. It is generally better to use QMC. But do check out Vlados tutorials. Link to comment Share on other sites More sharing options...
yogeshwagh Posted May 10, 2006 Author Share Posted May 10, 2006 hi , its great christopher nichols is replying me. thanks for giving me reply and solution. i will check it out with primary engine with qmc , and secondary with lightcache. but if we make multiframe increamental option on with irradiance will it be works or it takes more time? thanks again, Link to comment Share on other sites More sharing options...
ApeiNe Posted May 10, 2006 Share Posted May 10, 2006 What do you think about "turn up the quality a lot" ? can't you share any parameters ? that would be really appreciate Link to comment Share on other sites More sharing options...
yogeshwagh Posted May 10, 2006 Author Share Posted May 10, 2006 hi thanks for reply, i am using lightcache with less subdivs. which decrease the render time. if u r using greater than 500 it takes so much time to calculate lightcache. but i think if we use qmc for primary then the subdiv parameter for lightcache has to be around 500 to 800. and for more quality just try to increase the subdivs of qmc gi, u can get the more quality but it takes more time to calculate. thanks for replying again Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 10, 2006 Share Posted May 10, 2006 What do you think about "turn up the quality a lot" ? can't you share any parameters ? that would be really appreciate Sure.. you know that preset called "High - Animation"? That is what it was designed for. Not only does it turn up the min/max settings, but it also increases the Distance threachhold and the GI Blur. This helps with things like animated charaters, and cases like such as when their feet approach the floors. On the other hand, in many cases it is easier to simply use QMC. Link to comment Share on other sites More sharing options...
yogeshwagh Posted May 10, 2006 Author Share Posted May 10, 2006 hi, thanks for reply, the solution which u had given , is it works with moving objects using iraadiance as primary engine. hight animtaion parameters take 4 passes to calculate irradiance. My animation is of 450 frames and after every 100th frame my objects are moving , its just like doors are open and i am entering , the same for 200th, 300th, and 400th, frame. if i use irradiance for primary with high animation will it be works for 100th , 200th ,300th ,400th frame ? Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 10, 2006 Share Posted May 10, 2006 No... you can use the irradiance map, but you can't use a saved irradiance map file. You have to calculate the irradiance map for every frame in full. If I were you, I would simply use the QMC. Link to comment Share on other sites More sharing options...
yogeshwagh Posted May 10, 2006 Author Share Posted May 10, 2006 hi thanks for reply, u mean to say i have to use primary engine to qmc and secondary to lightcache right? will it be works. but if i use lightcache sibdivs around 2000 it takes more time to rencer in my animation, so can u please help to reduce my rendertime with some optimum settings, Link to comment Share on other sites More sharing options...
visions Posted May 10, 2006 Share Posted May 10, 2006 Yogesh, Since you seem to be a registered user of Vray, why dont you ask your question in the Chaos group Vray forum. I am sure you will get a lot of information there Cheers Vivek Link to comment Share on other sites More sharing options...
Msamir Posted May 10, 2006 Share Posted May 10, 2006 As he'll get alot of information here too ! Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 10, 2006 Share Posted May 10, 2006 hi thanks for reply, u mean to say i have to use primary engine to qmc and secondary to lightcache right? will it be works. but if i use lightcache sibdivs around 2000 it takes more time to rencer in my animation, so can u please help to reduce my rendertime with some optimum settings, 2000 is way to high.... you only need to do that if you are saving your lightcache, which is this case you are not. You can get away with 500 or so, depending on the res of your animation. Link to comment Share on other sites More sharing options...
yogeshwagh Posted May 11, 2006 Author Share Posted May 11, 2006 hi , thank you very much for helping me out with the lightcache settings. My animation Frame Size is 1920 X 1020 pixels. So if i put 500 subdivs to lightcache it reduces rendertime but i loose the quality of animation. Thanks again for replying me and helping me. I have tried with subdiv level to 1200 it works with quality but takes time to render but it is fine with me. Yogesh Wagh Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 11, 2006 Share Posted May 11, 2006 yeah at that res, 1200 sounds better. for vid res you can get away with 500 Link to comment Share on other sites More sharing options...
yogeshwagh Posted May 11, 2006 Author Share Posted May 11, 2006 hi, yeah it works fine , can you please tell me how do i set the settings for QMC which reduces the rendertime. b'cose on 1920 X 1080 Pixels per frame it takes approx 1 hour to render, is it possible b'cose of My QMC Settings . My settings are Adaptive Subdivision :- By default settings Primary Engine :- QMC Secondary Engine :- Lightcache Adaptive QMC Settings Noise Thrshold :- 0.001 Adaptive samples :- 8 instead of 4 GI Subdivs Multiplier :- 8 instead of 1 and min samples :- 1 instead of 0.085 and Minimum samples for QMC :- 8 by default Link to comment Share on other sites More sharing options...
ApeiNe Posted May 11, 2006 Share Posted May 11, 2006 Noise threshold is the primary factor of rendertime.. u can try a 0,002 but the quality will be half. U should bettre try to work on shaders reducing maxdepth or subdivs on some materials u can. Link to comment Share on other sites More sharing options...
yogeshwagh Posted May 11, 2006 Author Share Posted May 11, 2006 hi, thanks for reply , Where can i find the shaders to reduce maxdepth and how can i reduce subdivs on some materials ? please help Yogesh wagh Link to comment Share on other sites More sharing options...
ApeiNe Posted May 13, 2006 Share Posted May 13, 2006 U can do a general setting on Vray::Genrel Settings (override all materials) Or just opening the material editor, in reflection and refraction panel of VrayMtl, u can set maxdepth and subivs... This will give u a better control. Link to comment Share on other sites More sharing options...
yogeshwagh Posted May 14, 2006 Author Share Posted May 14, 2006 hi thank you for helping me with your suggestions:D , i will try it, thanks again Link to comment Share on other sites More sharing options...
gsscott50@hotmail.com Posted March 23, 2009 Share Posted March 23, 2009 vlado posted this solution for GI solution with Vray 1.5 SP3 for animations with moving objects. http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=44223&highlight=animation+settings&page=2 Think you will need to be a registered user to see it though.... Link to comment Share on other sites More sharing options...
