John Martin Posted July 13, 2006 Share Posted July 13, 2006 Hi all, I am looking to see if this method will work well for creating Vray proxies of Onyx trees (I only have the broadleaf and conifer packages and not treestorm) create tree in Onyx (how do I make leaves basic geometry and not opacity mapped since this will be not be a closeup render and I do not need the detail) export out to 3DS import tree into Max apply materials to trees not using opacity mapped materials convert to vrmesh and create proxy scatter proxy as necessary Is this correct? I posted on the chaos website as well so I thought I would ask here as well. Link to comment Share on other sites More sharing options...
BrianKitts Posted July 13, 2006 Share Posted July 13, 2006 yup that'll do it, just make sure in Onyx you select your leaf type to get the desired look you want since you won't be mapping anything onto the leaf plate. Link to comment Share on other sites More sharing options...
kwerch Posted October 20, 2006 Share Posted October 20, 2006 Hey-Been following the links on this area on dealkingwith mapping the onyx trees in vray- Got that down- thx! I can't find the scatter for these vray proxies, however- could you give me some advice on achieving this? thx- Link to comment Share on other sites More sharing options...
Tyorl Posted October 30, 2006 Share Posted October 30, 2006 Try to use Scatter from Peter Watje. It is more powerfull then standart Scatter in MAX. Link to comment Share on other sites More sharing options...
ShaunDon Posted January 3, 2007 Share Posted January 3, 2007 Hey guys, gonna bump this thread now -- the Scatter plugin you're referring to Tyrol was last compiled in 2001 for max4, so unfortunately it doesn't work for 8. Anyone have any other possibilities for scattering objects? I need to do a forest comprised of different VRay proxies, but painting them all with Advanced Painter would take forever... Thanks! Shaun Link to comment Share on other sites More sharing options...
pentool Posted March 28, 2007 Share Posted March 28, 2007 Anyone have any other possibilities for scattering objects? www.gugila.com It has a free version, too. Does scattering with a ton of options. Link to comment Share on other sites More sharing options...
