robertsalmon Posted October 19, 2006 Share Posted October 19, 2006 Upon a quick search, i have found no answers to this question although i apologise if i am repeating a previously answered question. When modelling in sketchup and importing to Max , is there a way to avoid faceted faces on the curves. Note - I have tried the smooth modifier to no-avail. I feel that this may be because max is reading shapes such as cylinders as a series of faces, so when using the smooth modifier, it merely smooths each face, and not the object as a whole. Any ideas as to a quick fix for this problem would be greatly appreciated. Pre-emptive Thanks Robert. Link to comment Share on other sites More sharing options...
martin walker Posted October 19, 2006 Share Posted October 19, 2006 use the autosmooth in Max.....its the wy the normals are imported in on the faces in question....its not actually altering your geometry Link to comment Share on other sites More sharing options...
AJLynn Posted October 19, 2006 Share Posted October 19, 2006 Also, remember that Sketchup curves aren't real curves - it's faceted geometry with a curve flag that Sketchup reads. That isn't compatible with the file formats used for transferring to other program, so you need to find the equivalent in your other program and use it (like Autosmooth, as Martin said). Link to comment Share on other sites More sharing options...
robertsalmon Posted October 19, 2006 Author Share Posted October 19, 2006 Thanks for your quick reply Martin, but unfortunately the auto-smooth wields the same results. ie.- nothing. Think I may have to remodel the curved parts in autocad, and import. robert Link to comment Share on other sites More sharing options...
creasia Posted October 25, 2006 Share Posted October 25, 2006 We see this all the time at my employment. You need to make sure all the verticies are welded together first, then select the mesh at the polygon level, clear all smoothing at the bottom of the max edit mesh modifier and then apply an autosmooth. Hope this helps Shaun Link to comment Share on other sites More sharing options...
siliconbauhaus Posted October 26, 2006 Share Posted October 26, 2006 just out of interest, how many segments do you have in your curves before exporting ? Link to comment Share on other sites More sharing options...
robertsalmon Posted November 1, 2006 Author Share Posted November 1, 2006 Problem Solved, turns out that i just had to weld the faces. A simple error , a simple problem and thankfully, a simple solution. Thank you all for your help. Robert Link to comment Share on other sites More sharing options...
