mbr Posted January 21, 2003 Share Posted January 21, 2003 I am not familiar with Arch Desktop at all and a client has a file with 'smart walls'. I've seen the elevations but don't know if this is a complete 3D model or not. Any help would be appreciated. So I'll need to figure out if it can be eventually imported/opened in Max. Thanks. Link to comment Share on other sites More sharing options...
Cesar R Posted January 21, 2003 Share Posted January 21, 2003 yes i can be opened it max. It would be even better if you had VIZ and used the FILE LINK feature. However you can download a path form discreet that will enable similar functions in max, ortherwise just export to 3ds. Keep in mind however that the AEC wall - "smart walls" are only "smart in architectural desktop. Link to comment Share on other sites More sharing options...
Kerry Thompson Posted January 21, 2003 Share Posted January 21, 2003 Hi mbr The ADT objects can be directly linked to Viz but they can also be exploded into their base geometry losing their “smartness” Ask you client to copy the original file and under the ADT pull down menu, select Desktop > Utilities > Explode AEC objects. This will go through the file and turn walls into AutoCAD 3dface constructions. Carry this operation in a “model” display representation to show the 3D data. Regards Kerry Thompson Link to comment Share on other sites More sharing options...
mbr Posted January 22, 2003 Author Share Posted January 22, 2003 Much thanks, guys. That was a big help. Link to comment Share on other sites More sharing options...
