quizzy Posted September 17, 2002 Share Posted September 17, 2002 ok guys and girl(s), Some of us have problems seeing the images that are uploaded with the upload utility, you'll propably see this image: Well the problem is that you are behind a firewall that won't let you HTTP_REFERAL and/or HTTP_REQUEST. To solve this problem: Go to the firewall preferences, if its soft- or hardware it does not matter. In the preferences look for outgoing ip adresses that are allowed or blocked. In these settings make sure that the following ip adresses are allowed: 207.176.130.146 this is www.cgarchitect.com and 207.176.130.32 this is ns29.zabco.net which is propably the server where CGA is hosted (Jeff??) This should solve your problems, it has nothing to do with explorer types or versions, since you can not set these kind of ip-settings in it.. Helpfully yours: Link to comment Share on other sites More sharing options...
STRAT Posted September 17, 2002 Share Posted September 17, 2002 are you all fixed then? i've found another image uploader. can you see this? if you can, try it out. here it is - http://uploader.axsstudios.com/ this uploader is curtasy of a m8, so please read the rules ppl, and dont abuse it Link to comment Share on other sites More sharing options...
quizzy Posted September 17, 2002 Author Share Posted September 17, 2002 yep it all works now... Link to comment Share on other sites More sharing options...
Jeff Mottle Posted September 17, 2002 Share Posted September 17, 2002 Thanks Quizzy!! Thank you VERY much!! I knew from reading on the net that the problem was related to firewalls and browsers, but I just didn't know how to fix it exactly. One thing that I need to correct you on is that Browsers CAN affect these REQUESTS. Some broesers DO allow you to block HTTP_REQUEST and REFERER. And yes those IPs are correct, although do change every now and then when my host upgrades their facility. I've updated the error messgase to reflect your findings. Cheers, Jeff Link to comment Share on other sites More sharing options...
quizzy Posted September 17, 2002 Author Share Posted September 17, 2002 well maybe some browsers can affect the referal and request thingy's but not IE6 and netscape4.2 at least I couldn't find it.. but anyway... glad to be of some help... Link to comment Share on other sites More sharing options...
