1eo Posted March 1, 2007 Share Posted March 1, 2007 Hello, This is a problem, that I have been dealing for a while and I don't how to fix it. Lets say, I get a dwg land survey from a surveyor... if I try to copy/pasted a into an existing drawing, the scale is off. I have try changing in Format- Units ... and I set both drawings (the survey and my drawings) to have the same units. But that doesn't fix my problem. what could it be?? leo Link to comment Share on other sites More sharing options...
classix Posted March 1, 2007 Share Posted March 1, 2007 check two settings: format > units > drawing units options > user settings > insunits in our office we have a acaddoc.lsp: (setvar "INSUNITS" 6) (setvar "INSUNITSDEFSOURCE" 6) (setvar "INSUNITSDEFTARGET" 6) making sure any drawing is set to the same units Hope that hepls Marcus http://www.einherzfuerpixel.de Link to comment Share on other sites More sharing options...
neko Posted March 1, 2007 Share Posted March 1, 2007 surveyors typically work in meters (or maybe in feet in USA ?) whatever the case, are you sure that you are accounting for this discrepancy ? it is one thing to be in the same units (architectural or decimal) but another to be working with the same base unit (inch vs feet or millimeters vs meters) it could also be the insert units as sugested by marcus. i never cut and paste in autocad, by the way - try inserting as a block. hope that helps paul Link to comment Share on other sites More sharing options...
vizwhiz Posted March 1, 2007 Share Posted March 1, 2007 Leo from previous experience i have always have had To scale UP The civil dwg by 12 They work in 1.0 = 1 FOOT units so To convert into architectural you would need To multiply by 12 inches per Foot This is old-style autocad workflow so not exactly sure if This is you ADT problem say did you hear That They are renaming ADT To ACA? Autocad for Architects ** Thanks Randy i am not civil, never have been, never will be Link to comment Share on other sites More sharing options...
Audrie Posted March 2, 2007 Share Posted March 2, 2007 Not sure why you aren't referencing it in.... Link to comment Share on other sites More sharing options...
1eo Posted March 2, 2007 Author Share Posted March 2, 2007 Well, the drawing needed to be scale by 12 juat like vizwhiz said. Quote Not sure why you aren't referencing it in.... I'm not an expert in autocad, but the layer system that the surveyor had was differnt from ours, besides I didn't need all the info on the plans and the text needed to be in a different size. So what I did is "converted" what we needed to our layer system and the xref it to the plans. Is there a better way to do it? Link to comment Share on other sites More sharing options...
