al_farooq Posted March 9, 2007 Share Posted March 9, 2007 hi all, i want to create tile patterns in studiomax how i can do? for example i have two kind tiles and one smaller frame between these tiles .becare full i want to use tiles original measurments how and where from i will set measurments of my tiles.explaination of room and tiles is given below 1-room length 5000mm=5m 2-room width4000mm=4m 3-white tile 400mm=40cm square 2-black tile 400mm=40cm square 3-strip length 400mm=40cm,width 150mm=15cm, that is gray colour how i want to fix tiles first of all two black tiles beside all walls the gray strip after that in the strip rectangle i want to fix white colour tiles. i will b thank full to all my friends which will help me about tile pattrens in stu dio max i want to fix floor tiles in so many patters.so may i prepare my pattern first in autocad then importing in studio max or whole work will b done in studiomax pls answer quickly with best regards m.umer.farooq Link to comment Share on other sites More sharing options...
cloaked_spectre Posted March 9, 2007 Share Posted March 9, 2007 create a single compound bitmap tile of all these tiles laid out and sized the way you want in a photoshop type program (I use GIMP), then you can just apply as a material in max....you will need to create separate rectangular surfaces in max for the different tile type and patterns, probably, based on your description, separate concentric rectangles...... Link to comment Share on other sites More sharing options...
