redzuan3828 Posted March 19, 2007 Share Posted March 19, 2007 hai everyone... How to adjust background image in viewport??? someone can teach me? i want to adjust background because to adjust my horizontal line the black line is what i don't want. you can see from my test image thanks guy:) Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted March 19, 2007 Share Posted March 19, 2007 hit alt+b on your keyboard to bring up the viewport background options. If you have already added an image to the background, you can check the box next to "use environment background" In the lower right, check the box marked "display background". If you want to view the image as it will be rendered, do not check the box marked, "lock Zoom/Pan" ----- If you want to adjust the position of your background in the viewport and see it as it will be rendered, do the following: 1) In the material editor slot click the "get material button" (first button on the left, directly under the material slots) 2) Choose bitmap from the menu 3) select a file and select "enviroment" in the coordinates roll out in the material editor. Choose a mapping method (usually "screen" for a simple image) 4) hit "8" on your keyboard and drag the material from the material editor into the environment slot, choose "instance" 5) hit "alt+b" on your keyboard and display the enviroment as displayed above. 6) whilst viewing the required camera view in the viewport, adjust the scaling and offset of the bitmap image in the material editor. You will be able to see the image moving around in the viewport and it should give a good aproximation of how the image will render. -edit: It is best to do this with safe frames switched on (hit "shift+f" on your keyboard. I've assumed you are using some of the default shortcuts. Link to comment Share on other sites More sharing options...
Brian Smith Posted March 19, 2007 Share Posted March 19, 2007 do yourself a favor and use physical objects to map your background....far better in so many ways Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted March 19, 2007 Share Posted March 19, 2007 ^^^^^^ This is absolutely true. Far easier to animate and much easier to control. however I did answer the question in the OP pretty well I thought Link to comment Share on other sites More sharing options...
redzuan3828 Posted March 20, 2007 Author Share Posted March 20, 2007 thanks guy your help and opinion Link to comment Share on other sites More sharing options...
Brian Smith Posted March 20, 2007 Share Posted March 20, 2007 ^^^^^^ however I did answer the question in the OP pretty well I thought You sure did. Kev..btw, noticed you're from Nepal (though currently in Shanghai). Do any serious climbing there? Used to be on a mountaineering team but i live Florida now where the highest point of elevation is about 150 feet above sea level. Link to comment Share on other sites More sharing options...
redzuan3828 Posted March 20, 2007 Author Share Posted March 20, 2007 do yourself a favor and use physical objects to map your background....far better in so many ways I try to use HDRI vray for still image only because the effect is very nice to me. I just follow the tutorial done by Paco Morales from mexico this image look fine but i just wonder if I can do other project later that need to adjust the horizontal line.... that worries me...... do you have any opinion Brian??? Link to comment Share on other sites More sharing options...
